z axis moves up and down while printing
i had a tronxy x5sa 400 and board died so i got a duet 2 wifi and am now trying to print and z axis moves up and down while printing but homes and moves properly using interface any help would be much appreciated
also when i try to use mesh leveling it only goes up to x200 y200 and has 100 points would like to have 16 points if that's possible
Please find config x y and z home attachedconfig
[5_1556215753905_homez.g](Uploading 100%) [4_1556215753905_homey.g](Uploading 100%) [3_1556215753905_homex.g](Uploading 100%) [2_1556215753904_homeall.g](Uploading 100%) [1_1556215753904_config.json](Uploading 100%) [0_1556215753903_config.g](Uploading 100%)
; generated by RepRapFirmware Configuration Tool v2 on Mon Apr 22 2019 20:39:23 GMT+0100 (British Summer Time); General preferences
M83 ; ...but relative extruder movesM667 S1 ; Select CoreXY mode
M550 P"Tronxy" ; Set machine name
M552 S1 ; Enable network
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P3 S1 ; Drive 3 goes backwards
M92 X80.00 Y80.00 Z400.00 E98.00 ; Set steps per mm
M566 X600.00 Y600.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z180.00 E1500.00 ; Set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; Set accelerations (mm/s^2)
M906 X950.00 Y950.00 Z950.00 E950.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
M208 X400 Y400 Z400 S0 ; Set axis maxima; Endstops
M574 X1 Y1 Z1 S0 ; Set active low and disabled endstops; Z-Probe
M558 P0 H5 F0 T6000 ; Set Z probe type to switch and the dive height + speeds
G31 P600 X200 Y200 Z-0.55 ; Set Z probe trigger value, offset and trigger height
M557 X15:385 Y15:385 S20 ; Define mesh grid; Heaters
M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic power saving
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss; Custom settings are not configured
@xbrmxjamie said in z axis moves up and down while printing:
The X and Y values in G31 refer to the placement of the z probe relative to the nozzle.
M558 P0 indicates that there is no probe and to use manual jogging to bring the nozzle to touch the bed, so your X Y and Z values should all be 0 since that's the point where the nozzle is touching the bed.
You'll have to redo your mesh grid after fixing that.
finally for a chance to change these settings now i need to sort out mesh levelling currently it only does 200x200 i need 400x400
M587 S"Configure access point and IP addresses. You can delete this line once connected
G31 P600 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
I don't see anything in that file that would cause it not to probe the full 400x400, however you are using config-override.g, so please post that file too. Also post your bed.g file if you are using one.
; bed.g
G29 ; probe the bed and enable compensation; Configuration file for Duet WiFi (firmware version 1.21)
M587 S"; Configure access point and IP addresses. You can delete this line once connected
M501 ; Load saved parameters from non-volatile memorycant find file config-override.g above is config.g.bak
If you send M557 with no parameters from the GCode Console, what response do you get?
@dc42 said in z axis moves up and down while printing:
M557
M557
Grid: X15.0:385.0, Y15.0:385.0, radius -1.0, X spacing 20.0, Y spacing 20.0, 361 points
That looks OK. What happens when you send G29? Also, which firmware version are you using? Send M115 to find out.
