    Can't run homex.g with M98
    My Duet controlled machine
    • fwny
      fwny last edited by
      I am trying to run homex.g via M98 and it seems to produce the following error:
      12:00:39 AM
      M98 P"homex.g"
      Error: G0/G1: insufficient axes homed
      The contents of the file are
      ; X axis homing file for dc42 Duet firmware
      G91
      G1 Z4 F200 S2
      G1 X-280 F3000 S1
      G1 X4 F600
      G1 X-10 S1
      G1 Z-4 F200
      G90
      I can run the contents myself with no issues at all. It is only when I try to invoke with M98 does this issue arise.
      Here is my config.g:
      ; Configuration file for My Printer
      ; Communication and general
      M111 S0 ; Debug off
      M550 PRailCore ; Machine name and Netbios name (can be anything you like)
      ;M551 Pmyrap ; Machine password (used for FTP)
      ;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
      M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xEE ; MAC Address
      ;*** Wifi Networking
      M552 S1 ; Enable WiFi
      M555 P2 ; Set output to look like Marlin
      M575 P1 B57600 S1 ; Comms parameters for PanelDue
      G21 ; Work in millimetres
      ; Axis and motor configuration
      M669 K1 ; CoreXY mode
      M584 X0 Y1 Z5:6:7 E3:4:8:9 ; Map Z to drivers 5, 6, 7. Define unused drivers 3,4,8 and 9 as extruders
      M569 P0 S1 ; Drive 0 goes forwards (change to S0 to reverse it) X stepper (Rear)
      M569 P1 S0 ; Drive 1 goes backwards Y Stepper (Front)
      M569 P2 S1 ; Drive 2 goes forwards Unused
      M569 P3 S1 ; Drive 3 goes forwards Extruder
      M569 P4 S1 ; Drive 4 goes forwards Extruder (unused)
      M569 P5 S0 ; Drive 5 goes backwards Front Left Z
      M569 P6 S0 ; Drive 6 goes backwards Rear Left Z
      M569 P7 S1 ; Drive 7 goes backwards Right Z
      ;Leadscrew locations
      M671 X-10:-10:344 Y21:275:146 S7.5 ;Front left, Rear Left, Right S7.5 is the max correction - measure your own offsets, to the bolt for the yoke of each leadscrew
      M350 X16 Y16 Z16 E16 I1 ; set 16x microstepping for axes& extruder, with interpolation
      M574 X1 Y1 Z0 S1 ; set homing switch configuration (x,y at min, z at max) IF YOU NEED TO REVERSE YOUR HOMING SWITCHES CHANGE S1 to S0
      M906 X1400 Y1400 Z1000 E1250 I60 ; Set motor currents (mA)
      M201 X2500 Y2500 Z80 E1500 ; Accelerations (mm/s^2)
      M203 X24000 Y24000 Z900 E3600 ; Maximum speeds (mm/min)
      M566 X1000 Y1000 Z80 E1500 ; Maximum jerk speeds mm/minute
      M208 X295 Y300 Z330 ; set axis maxima and high homing switch positions (adjust to suit your machine)
      M208 X0 Y0 Z-0.5 S1 ; set axis minima and low homing switch positions (adjust to make X=0 and Y=0 the edges of the bed)
      M92 X200 Y200 Z1600 E837 ; steps/mm
      ; Thermistors
      M305 P0 T100000 B4240 R4700 H0 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
      M305 P1 T100000 B4725 R4700 H0 L0 C7.06e-8 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
      M305 P105 S"Keenovo" X5 T100000 B3950 R4700
      M307 H0 A276.1 C816.1 D11.9 S1.00 V24.3 B0 ; Bed Heaters
      M307 H1 A430.0 C241.4 D3.7 S1.00 V24.3 B0 ;Heater 1 model
      M570 S360 ; Hot end may be a little slow to heat up so allow it 180 seconds
      M143 S285
      M106 P0 H-1 ; disable thermostatic mode for fan 0
      M106 P1 T45 H1 ; enable thermostatic mode for fan 1
      M106 P2 H-1
      M106 P0 S0 ; turn off fans
      M106 P2 S0
      ; Tool definitions
      M563 P0 D0 H1 ; Define tool 0
      G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
      ;BLTouch - comment out the following 3 lines if using a IR Probe
      M307 H3 A-1 C-1 D-1
      M558 P9 X0 Y0 Z1 H5 F50 T6000 A5 S0.02
      G31 X2.3 Y41.6 Z2.73 P25 ; Customize your offsets appropriately - do a paper test, and put the probed value in the Z value here
      M208 S1 Z-0.2 ; set minimum Z
      T0 ; select first hot end
      M581 T1 E2 S0 C0 ;filament sentinel
      M557 X45:280 Y45:255 S210 ;configure mesh points
      I am running 2.02(RTOS) (2018-12-24b1)
        Does G28 X work?
        • fwny
          fwny last edited by fwny
          I think I may have solved it. Missing S2 on the second last line. That'll teach me to work on this stuff so late at night and tired.
