    Error when trying to view macros on PanelDue
    PanelDue
    1
    1
    245
      I've started to receive an error occasionally when trying to view the macros using the PanelDue. The error flashes on the display briefly and is half cut off but if I try a few times I can make out Error 2 accessing SD card. The rest of the controls work fine. This seems to happen mid-print at some point because I can view and execute macros at the start of the print. I can still run the macros using DWC. Soft reset doesn't clear it, but a power cycle does.
      PanelDue 7 v2 firmware 1.23.2, DuetWifi firmware 2.02, Using 4 wire connector.
