    at the circle pressure the pressure always stops
    384
    • 3dware
      3dware last edited by 3dware
      I make myself through various topics read here but still found no solution.
      my attitude are as follows:
      M584 X4 Y3:0 Z2:1 E5:6:7:8:9 ; Apply custom drive mapping
      M350 X64 Y64 Z64 E32:32:32:32:32 I0 ; Configure microstepping without interpolation
      M92 X1066.66 Y1066.66 Z6400 E953.00:953.00:953.00:953.00:953.00 ; Set steps per mm
      M566 X900.00 Y900.00 Z12.00 E900.00:900.00:900.00:900.00:900.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z800.00 E6000.00:6000.00:6000.00:6000.00:6000.00 ; Set maximum speeds (mm/min)
      M201 X400.00 Y400.00 Z10.00 E250.00:250.00:250.00:250.00:250.00 ; Set accelerations (mm/s^2)
      M906 X1800.00 Y1800.00 Z1800.00 E800.00:800.00:800.00:800.00:800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      0_1556604333899_Schubladen-Teiler.gcode
      I would be happy about your help.
      greetings soon
      Michel
      • 3dware
        I have now found that I have the same problem synonymous with solid infill when the lines are about 12mm long and.
        with reduction of the speed I have the problem no more.
        It may be that I'm too high with the steps.
        I use spindles on all axes.
        thx
        • Veti
          Veti last edited by
          can you post some pictures? i dont quite understand what you mean.
          • 3dware
            https://www.dropbox.com/s/hpg54rjg65v9m05/VID_20190430_102255.mp4?dl=0
            https://www.dropbox.com/s/iycyysksrpncgzx/VID_20190430_072844.mp4?dl=0
            greetz
              @3dware said in at the circle pressure the pressure always stops:
              I think you're right.
              Can you post the results of M122 diagnostics? I think we'll see hiccups.
              Try M350 X16 Y16 Z16 E16 I1 instead. This will use 16 microsteps for the calculation and interpolate the step pulses to 256 at the driver, which should be much quieter as well.
              You'll have to modify your M92 steps per mm to match x16 microsteps.
              • 3dware
                16:49:08
                M122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03beta3 running on Duet WiFi 1.02 or later + DueX5
                Board ID: 08DGM-917DA-G4MSD-6J1F8-3SN6N-KSTM9
                Used output buffers: 3 of 20 (18 max)
                Static ram: 25632
                Dynamic ram: 97108 of which 0 recycled
                Exception stack ram used: 472
                Never used ram: 7860
                Tasks: NETWORK(ready,564) HEAT(blocked,1172) MAIN(running,3732) IDLE(ready,196)
                Owned mutexes:
                Last reset 00:46:12 ago, cause: software
                Last software reset at 2019-04-30 16:02, reason: User, spinning module GCodes, available RAM 7856 bytes (slot 3)
                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                Error status: 8
                Free file entries: 9
                MCU temperature: min 26.3, current 26.6, max 26.9
                Supply voltage: min 23.8, current 23.9, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                Driver 0: ok, SG min/max 0/349
                Driver 3: ok, SG min/max 49/399
                Driver 4: ok, SG min/max 78/367
                Driver 5: ok, SG min/max not available
                Driver 6: standstill, SG min/max not available
                Driver 7: standstill, SG min/max not available
                Driver 8: standstill, SG min/max not available
                Driver 9: standstill, SG min/max not available
                Date/time: 2019-04-30 16:49:07
                Slowest loop: 6.89ms; fastest: 0.09ms
                I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
                Hiccups: 0, FreeDm: 165, MinFreeDm: 158, MaxWait: 0ms
                Bed compensation in use: mesh
                === MainDDARing ===
                Scheduled moves: 788, completed moves: 784, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                === AuxDDARing ===
                Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                Bed heaters = 0 -1 -1 -1, chamberHeaters = 6 -1
                Heater 0 is on, I-accum = 0.1
                Heater 1 is on, I-accum = 0.0
                Segments left: 1, aux move: no
                Movement lock held by null
                http is idle in state(s) 0
                telnet is idle in state(s) 0
                file is idle in state(s) 2
                serial is idle in state(s) 0
                aux is idle in state(s) 0
                daemon is idle in state(s) 0
                queue is idle in state(s) 0
                Code queue is empty.
                === Network ===
                Slowest loop: 167.81ms; fastest: 0.08ms
                HTTP sessions: 1 of 8
                • WiFi -
                  Network state is running
                  WiFi firmware version 1.21
                  WiFi MAC address cc:50:e3:0d:1b:66
                  WiFi Vcc 3.42, reset reason Turned on by main processor
                  WiFi flash size 4194304, free heap 16344
                  WiFi IP address 192.168.55.202
                  WiFi signal strength -55dBm, reconnections 0, sleep mode modem
                  Is that from immediately after the pauses in the print?
                  • 3dware
                    Hello
                    No, I have the M122 anywhere in between.
                    I have now set 1/16 and I1 and it seems to be exactly that.
                    now it looks good.
                    thanks for the competent help.
                    regards
