    Post Print Head Positioning
    • Qdeathstar
      Qdeathstar last edited by
      Hi.
      Right now, when my print is done the printer homes itself. This is a problem because i have a heated chamber and when the printer homes the wiring and water cooling hoses get too close to the heatlamp and melt. What i would like to do is to have the printer return to the center of bed and raise 10mm and stop.
      I'm sure this is possible but i cant seem to figure it out.
      Thanks! 😄
      • Jackal
        Jackal last edited by
        Try this in your ending gcode instead of G28
        G91 ;relative move
        G1 Z10 ;raise 10mm
        G90 :Absolute move
        G1 X0 Y0 ;Move to center (I assume it's a delta)
        You can add the F parameter in the G1 codes to control the speed
        • Qdeathstar
          Thanks, that works perfectly 😄
