    BLTouch wont deploy
    • Phillboundefined
      Phillbo
      Hope someone can help with this issue....
      I have an Ender 5 with a genuine v2.2 BlTouch that refuses to deploy when I home. I just replaced the Creality (BlTouch working fine) board with a Duet Maestro. When I click home all, the x and y axis home as normal, the bed moves up but the probe will not deploy.
      On power up the probe will do a self test with no error. I can also send M401 and M402 commands successfully.
      I'm quite new to the RepRap firmware so any help would be greatly appreciated.
      Thanks,
      Phill
      Config.g
      ; Configuration file for Duet Maestro (firmware version 1.21)
      ; generated by RepRapFirmware Configuration Tool v2 on Fri Apr 12 2019 09:17:10 GMT+1000 (Australian Eastern Standard Time)
      M550 P"Phill's Ender 5 Duet" ; Set machine name
      M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M350 X32 Y32 Z32 E64 I1 ; Configure microstepping with interpolation
      M92 X160.00 Y160.00 Z800.00 E407.44 ; Set steps per mm
      M566 X900.00 Y900.00 Z180.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z1200.00 E1200.00 ; Set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E250.00 ; Set accelerations (mm/s^2)
      M906 X800.00 Y800.00 Z800.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X230 Y225 Z300 S0 ; Set axis maxima
      M574 X1 Y1 Z1 S1 ; Set active high endstops
      M558 P9 H2 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
      G31 P25 X-44 Y-15 Z2.5 ; Set Z probe trigger value, offset and trigger height
      M557 X15:6 Y15:195 S20 ; Define mesh grid
      M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
      M305 P0 T100000 B4138 R2200 ; Set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4138 R2200 ; Set thermistor + ADC parameters for heater 1
      M106 P0 S0.65 I0 F20 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S0.65 I0 F20 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P2 S0.85 I0 F5000 H1 T100 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 ; Define tool 0
      ; Custom settings
      Deployprobe.g
      ; deployprobe.g
      ; called to deploy a physical Z probe
      ; generated by RepRapFirmware Configuration Tool v2 on Fri Apr 12 2019 09:17:11 GMT+1000 (Australian Eastern Standard Time)
      M280 P64 S10
      Retractprobe.g
      ; retractprobe.g
      ; called to retract a physical Z probe
      M280 P64 S90
      Homez.g
      ; homez.g
      ; called to home the Z axis
      ; generated by RepRapFirmware Configuration Tool v2 on Fri Apr 12 2019 09:17:12 GMT+1000 (Australian Eastern Standard Time)
      G91 ; relative positioning
      G1 Z2 F6000 S2 ; lift Z relative to current position
      G90 ; absolute positioning
      G1 S1 Z-305 F3000 ; move Z down until the endstop is triggered
      G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
      G1 S2 Z2 F100 ; lift Z relative to current position
      • Vetiundefined
        Veti
        can you post your homeall.g ?
          Phaedrux Moderator @Phillbo
          @phillbo said in BLTouch wont deploy:
          You need to remove that form homez and I am going to guess it's in homeall as well.
          Also, M558 H2 is a pretty low dive height for the BLTouch. Just make sure you have enough distance between the probe and the bed for the pin to successfully drop and settle.
          • Phillboundefined
            Phillbo
            I've removed G92 from both Homez and homeall. Probe still wont deploy prior to bed moving up?
            link to vid showing issue..https://youtu.be/6YenXoKvd_w
            ; homeall.g
            ; called to home all axes
            G1 S1 X-235 Y-230 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
            G1 X5 Y5 F6000 ; go back a few mm
            G1 S1 X-235 Y-230 F360 ; move slowly to X and Y axis endstops once more (second pass)
            G1 S1 Z-305 F3000 ; move Z down stopping at the endstop
            ;G92 Z0 ; set Z to axis minimum (you may want to adjust this)
            ;G91 ; relative positioning
            ;G1 S2 Z2 F100 ; lift Z relative to current position
            ;G90 ; absolute positioning
              You've also removed the G30. You'll need to actually probe the bed.
              So remove G1 S1 Z-305 F3000 ; move Z down stopping at the endstop and replace it with G30
              • Phillboundefined
                Phillbo
                Thank you Phaedrux. Homing the z axis now works perfectly.....Why aren't these settings correctly added when running the config?
                  @phillbo strange. Did you choose BLTouch in the configurator and select none for z endstop?
