    Controlling a fan via wall outlet
    • injoi9000
      injoi9000 last edited by
      I am trying to control a 230VAC blower via the DUET WIFI. Is there a simple way to do this using the PWM ports on the Duex5? Here is the fan for reference: https://www.galco.com/buy/ebm-papst-Inc./G2E085-AA01-05?source=googleshopping&utm_source=adwords&utm_campaign=&gclid=Cj0KCQjwtr_mBRDeARIsALfBZA7xspMYZZMCGIxpme3CeC4L3tr1tYPdUi0FrJGCjC8uawJYDY26TJEaApIsEALw_wcB
      • DocTrucker
        DocTrucker last edited by DocTrucker
        PWM is a good way to throttle DC devices but for AC motors you generally need an inverter that goes AC to DC to AC where the frequency of the final AC controls the motor speed.
        You may be able to drive an inverter via a PWM signal or perhaps build yourself a voltage divider and smoothing circuit to convert the PWM into a 0-10V signal which is often used by industrial equipment. The alternative 4-20mA would be a little more tricky!
        Alive: 1 Ormerodish machines. 1 Custom Cantilever. 3 P3Steel. 1 Ciclopish scanner. In build: 1 P3Steel. Controllers: 2 Duet 2 , 2 D0.6, 1 D0.8.5, 1 D3 v0.5, 1 RAMPS/DRV8825, 1 Uno/Scan Card.
