    Duet settings for DC42’s Precision Kossel
    • ra_v
      ra_v last edited by
      Hello!
      I build my first delta printer as described on DC42’s Precision Kossel blog. Many thanks to David! Please help me with Duet 2 WiFi v.2.02 settings on the сonfigurator.reprapfirmware.org page. There are a lot of parameters that I do not quite understand. I did the initial Duet setup, Duet Web Control works well.I use stepper motors 17HM19-2004S and Wantai 42BYGHW609P1 for the Nimble Remote Direct Drive extruder. Going to use a Berd-Air MAX-24 blower. Perhaps somewhere there is a detailed description of the settings for this particular printer or a ready configuration file or at least all the parameters that need to be set on the page. Thanks
      • Veti
        Veti last edited by
        the settings are on his github page
        https://github.com/dc42/RepRapFirmware/tree/dev/SD-image/sys-dc42Kossel
          In fairness, those settings date from when that printer used a Duet 085. I will update them to my current configuration shortly.
            I've updated those files, currently only in the v2-dev branch. See https://github.com/dc42/RepRapFirmware/tree/v3-dev/SD-image/sys-dc42Kossel.
            • ra_v
              ra_v last edited by
              Thank you very much, David!
