    Higher fidelity on PWM on DUEX5
    • injoi9000
      injoi9000 last edited by
      I am using the PWM ports on the DUEX5 to control a fan with a speed controller. It appears I only have a resolution of S4... as in there is no change in speed between S70 until S74. Is there a way to get higher fidelity using the PWM M280 commands?
        The resolution should be 8 bits, because the SX1509B chip on the DueX provides 8 bit intensity control on the PWM output. Have you measured the output pulse timing using an oscilloscope?
        injoi9000 1 Reply Last reply Reply Quote 0
        • injoi9000
          injoi9000 @dc42 last edited by
          @dc42 I don't really understand...Does the 8 bit resolution map to a single "S1" digit?
          Unfortunately, I don't have an oscilloscope, is there any other way to debug this?
            I am sorry, I misread your post. I now see that you are using the PWM ports, not the fan ports.
            Please see this post https://forum.duet3d.com/topic/8453/microsecond-resolution-when-using-m280-for-servo-control. In summary, the following should improve the resolution:
            • Use firmware 2.03RC2 instead of firmware 2.02
            • Or use a PWM port controlled by a timer channel instead of a PWM channel
