    X Not moving when homing
    229
    • jackismad
      jackismad last edited by
      Hi Guys, So i have a bit of a weird issue.
      So. I got my printer priting well enough for now. Configured all the motors etc. Got it printing as best i could however because of my BL touch, the printer started printing off center. In a effort to fix this i changed the offset to the z prob in the config from -18 to 18. This resulted in the homing, going to x endstop then dropping. I then have to do a emergency stop before it hits the bed.
      From what i remember this is the only value i changed. I've changed it back to -18, 18, 30, -30 to see what happens and so far its just done nothing bar drop.
      Here is my Config.
      M550 P"Jack" ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S1 ; Enable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P2 S1 ; Drive 2 goes backwards
      M92 X160.00 Y160.00 Z800.00 E399.04 ; Set steps per mm
      M566 X600.00 Y600.00 Z180.00 E399.04 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E6000.00 ; Set maximum speeds (mm/min)
      M201 X1500.00 Y1500.00 Z100.00 E10000.00 ; Set accelerations (mm/s^2)
      M906 X500.00 Y500.00 Z500.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X30 Y-10 Z0 S1 ; Set axis minima
      M208 X220 Y220 Z200 S0 ; Set axis maxima
      M574 X1 Y1 S0 ; Set active low and disabled endstops
      M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
      M558 P9 H5 F120 T1500 ; Set Z probe type to bltouch and the dive height + speeds
      G31 P1 X-18 Y0 Z0.679 ; Set Z probe trigger value, offset and trigger height
      M557 X20:200 Y20:200 S40 ; Define mesh grid
      M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
      M305 P0 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 0
      M143 H0 S130 ; Set temperature limit for heater 0 to 130C
      M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
      M143 H1 S275 ; Set temperature limit for heater 1 to 275C
      M563 P0 D0 H1 ; Define tool 0
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      T0 ; Select first tool
      Thanks for the help
      • Veti
        Veti last edited by
        post all your homing scripts
        • jackismad
          Hi, They are..
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v2 on Sat Apr 13 2019 16:24:08 GMT+0100 (British Summer Time)
          G91 ; relative positioning
          G1 Z0 F1500 S2 ; lift Z relative to current position
          G1 S1 X-258 Y-235 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 X5 Y5 F1500 ; go back a few mm
          G1 S1 X-258 Y-235 F360 ; move slowly to X and Y axis endstops once more (second pass)
          G90 ; absolute positioning
          G1 X20 Y20 F1500 ; go to first bed probe point and home Z
          ;G91 ; relative positioning
          ;G1 S2 Z5 F25 ; lift Z relative to current position
          ;G90 ; absolute positioning
          ; homex.g
          ; called to home the X axis
          G1 Z5 F1500 S2 ; lift Z relative to current position
          G1 S1 X-258 F1800 ; move quickly to X axis endstop and stop there (first pass)
          G1 X5 F1500 ; go back a few mm
          G1 S1 X-258 F360 ; move slowly to X axis endstop once more (second pass)
          G1 Z-5 F1500 S2 ; lower Z again
          ; homey.g
          ; called to home the Y axis
          G1 S1 Y-235 F1800 ; move quickly to Y axis endstop and stop there (first pass)
          G1 Y5 F1500 ; go back a few mm
          G1 S1 Y-235 F360 ; move slowly to Y axis endstop once more (second pass)
          ; homez.g
          ; called to home the Z axis
          G1 X20 Y20 F1500 ; go to first probe point
          ;G30 ; Do a single probe to home our Z axis
          ;G90 ; Make sure we are in absolute mode
          ;G1 Z5 F6000 ; Rapidly move the Z axis to Z=10.
          • Veti
            Veti last edited by
            @jackismad said in X Not moving when homing:
            you need to move the grid as well by the 36 you have moved the offset
            • jackismad
              That makes sense! I've changed the value in x for the M557 Command to 56.
              However i still have the same issue. The X Will home, will stay where the endstop is then deploy probe and then Z will lower
              • Veti
                Veti last edited by
                this also seems wrong.
                this will prevent any movement below X30. you prob want X0 here
                • Veti
                  Veti last edited by
                  there should have been a message about this in the console log.
                  • jackismad
                    You, Legend! Its working, Not sure why i changed that, I did look in my console log but the only error is the Z probe failed to deploy, this was made when i emergency stopped.
