    Look like Marlin?
    • DanLundefined
      DanL
      In config.g, M555 P2 selects the option to "look like Marlin".
      I am using M584 to map drives. Marlin does not support M584, so should I not select "look like Marlin"?
      I commented out the M555... any issue with that?
      I also don't know where the different "looks" show up and if there are significant differences.
      Thanks.
      DanL
        The "Look like Marlin" refers to the responses sent to the USB and Telnet ports when GCode commands are received from those ports. The M555 setting doesn't affect what GCode commands are supported.
