    HomeAll.G content cleanup
    • AdamX
      AdamX last edited by
      I'm in the process of cleaning up my system files. I had been using the homeall.g generated by the config creation tool.
      Question is, is there a good reason NOT to replace homeall.g with the G28 for X Y and Z and leave it at that? Assuming the homex/y/z.g files are all correct, this seems a much more modular/efficient approach.
      Thoughts?
        dc42 administrators @AdamX last edited by
        @adamx said in HomeAll.G content cleanup:
        You mustn't use G28 commands inside homing files, although you can use M98 to call other homing files if you want. But here are two reasons not to:
        1. Typically you will raise Z by a few mm at the start of homex.g and homey.g to avoid scraping the nozzle over the bed if it is at Z=0. Then if you are using a Z probe to home Z, in homez.g you will probably raise it again prior to doing a G30 move. If your homeall.g file calls homez.g, homey.g and homez.g, then you will end up raising Z three times and lowering it twice, but you only need to raise it once.
        2. On Cartesian and CoreXY machines, you can home X and Y simultaneously.
        • AdamX
          Interesting... So substitute in a "G98 homez.g" and the like? I thought G28 Z (for example) just called the homez.g file?
          A Former User 1 Reply Last reply Reply Quote 0
          • A Former User
            A Former User @AdamX last edited by
            That is why I split the "hop" & "unhop" (ca. 10mm in z in my case) from the homing movements with currentreduction while homing, so to "hop" & "unhop" only 1 time no matter if only/and/or x/y/z. Drawback on this, you end up with 9 files: 1)homeall 2)...x 3)...y 4)...z 5)hop 6)unhop 7) actual-x-home-mvmnt 8)actual-y-home-mvmnt 9)actual-z-home-mvmnt
            Long story short: This way I could tune each individual movement/behaviour/current-reduction, but it gets a bit confusing also... because the 1)-4) are actually "empty" files calling the other submacros 5)-9)...
            • AdamX
              @lb that makes sense - but I'm still not tracking on why a G28 shouldn't/can't be called from homeall.g?
                It's because G28 uses some global flags to track which axes still need to be homed. So you might end up with fewer axes being homed than you wanted, or recursion, or something like that.
                AdamX 1 Reply Last reply Reply Quote 0
                • AdamX
                  AdamX @dc42 last edited by
                  @dc42 Aha, perfect! Thanks! I always like to know and... understand, so to speak 🙂
