    Full backup
    Duet Web Control wishlist
    12
    30
    3.1k
    • Exerqtorundefined
      Exerqtor
      Would be great to have a full backup function in the DWC, now that filament control have been implemented along with all the other macro's it's starting to be quite a bit of information/configeration excisting outisde the easily to backup /sys/. Don't want / need a way to "import" and full backup to the SDcard, but a way to get all the files off it and to a downloadable .zip or something without having to remove the SDcard and insert it to a computer.
      • A Former User?
        A Former User
        not super convenient but ftp is relatively easy. could automate with wget.
        • Exerqtorundefined
          Exerqtor
          Yeah sure i can fire up winscp and do it that way, but since we already spend alot of time inside the DWC i think it's unnecessary having to use another tool to do the same job.
            I'm not sure, but I think part of the limitation with getting the DWC to do heavy file processing is the relatively weak CPU which is not suited to the task, plus the waiting for SD card reads and folder recursion.
            I think it's impressive that it can do a full folder download as a zip file. Maybe that changes with the Duet 3 and the single board computer since those tasks then become trivial, but for now FTP really is best way to do it at the moment.
            But I totally agree with your request. It would be great to have an automated backup and restore option built in.
            Exerqtorundefined DocTruckerundefined 2 Replies Last reply Reply Quote 0
            • Exerqtorundefined
              Exerqtor @Phaedrux
              @phaedrux
              True, i don't need the ability to compress it before downloading either. But a function to at least download the whole contet of the sdcard would be so nice.
              When/if something goes titsup like a sdcard corruption or the board dying i don't need the ability to upload/restore it from the DWC. But if i atleast have a full backup laying there it makes the recovery job so much easier. Compared to either downloading it via FTP or pulling out the card and putting it in a PC (getting the card out means having to disasemble the whole board, because my enclosure don't have access slots).
              • A Former User?
                A Former User
                wget is pretty simple: wget -X /gcodes -r ftp://10.10.0.169/* downloads everything except the gcodes folder into a 10.10.0.169 folder locally.
                but yes, it'd be a nice to have feature in the DWC, but while you wait ☝
                Exerqtorundefined DonStaufferundefined 2 Replies Last reply Reply Quote 1
                • Exerqtorundefined
                  Exerqtor @A Former User
                  @bearer Never used or heard of wget before so thanks for the pointer 😁
                  Would still be awesome with a backup utility though 😂 Don't know how into networking HW you guys here are, but take the Ubiquiti UNIFI/CloudKey setup. The CloudKey does a backup of the entire sdcard content at a set time intervall. That way one atleast have something to revert to if something goes horribly wrong. Dosn't help much if the sdcard f's up. But it's something, and the backup could be stored in the /sys/ whos's easily accessable for if one want to fetch it.
                  • A Former User?
                    A Former User
                    add cron or a scheduled task in windows and you have regular backups. toss git in there and you have revision control, potentially offsite with bitbucket/github/whatnot.
                    might not be a one-click solution, but you only need to set it up once.
                      Well you can down load the whole sys folder and each macro folder from the DWC. So that's pretty much all you need for a recovery.
                      • DocTruckerundefined
                        DocTrucker @Phaedrux
                        @phaedrux said in Full backup:
                        I didn't think the duet was doing much of the leg work with regards to the website. I thought that the web page files were served to the browsing computer then they ran on that computer, commumicating with the duet using gcode, ftp, and maybe telnet?
                          Phaedrux Moderator @DocTrucker
                          @doctrucker Right, but to packup the files into a zip file and send it to you has to be done by the Duet.
                            dc42 administrators @Phaedrux
                            What happens with the existing backup of /sys and /macros is that DWC downloads each file individually and then zips them up.
                            DocTruckerundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                              DocTrucker @dc42
                              @dc42 ...and the processing is done on the remote computer rather than the duet right?
                              That's how I understood it anyway. All duet is doing is serving individual files to the remote computer.
                                Phaedrux Moderator @dc42
                                @dc42 said in Full backup:
                                Ah I see. In that case, would it be possible to download the entire contents of the card and zip it up in the same way?
                                  DocTrucker
                                  Possible, it's just a feature request for DWC as far as I can see.
                                  I agree it would be useful!
                                  • Danalundefined
                                    Danal
                                    Until this is implemented, going to the 3 places for gcode, system, and macros, then check all files and right click download zip, will be a yield a fairly complete protection of invested work.
                                    • A Former User?
                                      A Former User
                                      and /menu if using 12864 display.
                                      I'll stick with wget, if it gets a http url to hit instead that gets all the files, great, but ftp will also work as is.
                                      • Danalundefined
                                        Danal
                                        Also, just verified in github that DWC is pulling individual files from Duet, and zipping them on the browser (dwc) side. As everyone was saying above. Definitely works this way.
                                        DWC is using a unique service call, namely "rr_download,name=", so that it can get text or binary or whatever and add them to the zip.
                                        Therefore, implementing this is a matter of adding a button somewhere, adding code to 'walk' the entire directory tree of the SD, and the body of that code would be identical to what zips gcode or macros or whatever today. Absolutely no changes to Duet/RepRap firmware needed.
                                        Easy for Chris, and/or if there is enough commentary, I could give it a shot, and do it so that Chris can later pull it on git.
                                          dc42 administrators @Danal
                                          @danal said in Full backup:
                                          And Display if you are using a Duet Maestro.
                                          • XTLundefined
                                            XTL
                                            Recursive wget (and probably curl, automated browsers and many download managers) would also work great with http. Almost certainly better since the protocol is far more sane than ftp. All that would be required is some url with an html page with one link per file. Or one page per directory for a whole tree.
                                            Something that looks like the view you get when opening a directory or a web server served directory. Especially if you leave out sort columns or parent directory links so they don't need to be filtered out from the spider.
                                            resamundefined 1 Reply Last reply Reply Quote 0
