    Feature Req:Show current layer,total layers and total height
    PanelDue
    • makotosan
      makotosan last edited by
      It would be nice to be able to see on the PanelDue which layer is currently printing, as well as the total number of layers, and the total z-height of the print.
      makotosan 1 Reply Last reply Reply Quote 1
      • makotosan
        makotosan @makotosan last edited by
        I figured I'd take a stab at implementing this. Looks like the PanelDue is sending a "M408 S0" to get the current info. I was thinking of changing this to a "M408 S4" to get some additional info, and if the status is currently printing, send a "M36" to get stats of the current file.
          M408 S0 and S1 return a flat JSON object. M408 S2 to S5 return a nested JSON object. The parser in PanelDue didn't originally work with nested JSON objects, but I extended it a few versions ago. There were bugs in the original implementation, but I fixed those when I used the same parser in another project, and I back-ported the fixes to PanelDue in the latest revision. So it should be possible to use S2 instead of S0 now, and also to use S4; but you will need to change the variable names in table ReceiveDataTableEntry in PanelDue.cpp to match the names used in the S2 response.
          There is already code to process a M36 response, but currently it is only used in to display file info after selecting a print file.
