    Wiring External Machine Light Led Indicator Signal Tower
    • tmreith
      tmreith last edited by
      Is it possible to interface a multi-light signal tower to the Duet Wifi board? I'd like to be able to show a green status light when the machine is running a print, yellow light when in standby, and red when the machine is in alarm or fault mode.
      Has anyone had any success with a signal tower?
      • A Former User
        A Former User last edited by
        Think you'll have to look into
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M42_Switch_I_O_pin
        https://reprap.org/wiki/RepRap_Firmware_macros#System_macros
        add m42 to config.g to make it green, and add m42 to your start block in the slicer to make it yellow, add another few M42 to stop.g and/or cancel.g to turn back to green. make sure you add M0 to your slicer end block.
        there are pause.g and resume.g files as well if you want to change lights. Not sure about faults or alarms.
        you probaby can't drive any significant light directly from the IO pins unless the lights have integrated drivers
        • tmreith
          Nice idea. By using RGB LEDs this will work very well.
          https://toms3d.org/2017/07/16/software-controlled-leds/
