    Config.g form
    Firmware wishlist
    • idaho creator
      idaho creator last edited by
      It would be nice if config.g and other user editable system files were in a form format. You could just modify the form and it would edit the *.g file for you.
      • Jackal
        Jackal last edited by
        There are too many combinations for different setup.
        You can use the online configuration tool to edit your config.
        • T3P3Tony
          There is a longer term aspiration to more tightly integrate the functionality embodies in the configuration tool that Jackal linked with DuetWebControl. There is other work higher up the priority list right now though.
          Duet Hardware Designer
          www.duet3d.com
