    Heater Fault
    heater fault
    1.6k
    • A Former User?
      A Former User @justinds89
      @justinds89
      Search the forum for "heater fault" and or "temperature sensor problem" or alike
      I remember posts with:
      • either cables/connectors loose -> check if errors get worse/more with heated up parts while moving all axis/motors...
      • capacitive coupling between components (mains-earth and dc-ground e.g.); -> get a torch or your mobile-phone-led and check all wirings again and again...
      • "bad" temperature-sensor with wrong internal heat-conductive-isolating-filler that was throwing errors only over a certain temperature <- to be sure that is the problem you would have to reproduce your error in total standstill, no moving motors. If the error is only above a certain temperature and NEVER below a certain temperature, you might just have bough one of these, where the mfgr took the wrong thermal paste I guess...
      EDIT: hot-glue with not-conductive "glue" (most of the time you can get a chep hot glue explicit for "wiring/cables", that is the one you want)
        dc42 administrators @justinds89
        @justinds89 said in Heater Fault:
        Spoke too soon.
        Sudden random changes in temperature indication like that indicate a problem in the temperature sensor or its wiring. Not connected with heater tuning at all.
        • justinds89undefined
          justinds89
          Thanks for all the help guys!
          I swapped the termistor with another new one and so far it's been holding steady!
          Hopefully that was the problem.
