Paste extruder setup - print head and feeder (DUET-WIFI)
Hey there,
I've got a paste extruder setup which has a print-head and feeder (for the paste).
Was wondering how to setup the tools - the print-head is wired to E0 and feeder to E1.
Feeder should work (different steps) simultaneous with the print-head.
What should I put in the G-CODE?
Thanks.
CJ.
I suggest you configure the head as a mixing extruder with no heaters in M563, with mix ratio 1:1 in M567 and different steps/mm on each extruder as required.
like this ?
M563 P0 D0:1
also, how to run a G1 for specific extruder ? if G1 E100 it runs only E1..
thanks!
@cj-bravo said in Paste extruder setup - print head and feeder (DUET-WIFI):
like this ?
M563 P0 D0:1
thanks!
Not quite. You also need to set the mixing ratio as David said. So as well as M563 P0 D0:1, you also need M567 P0 E1.00:1.00 which will set both extruders to run at the same speed.
To run both extruders, you simply select Tool 0 then do your G1 Enn move. To use a particular extruder, you would use the format G1 En:n. So for example, if you wanted to extrude 5mm of filament at 300mm/minute using extruder drive 0 only, you would do something like
M83
G1 E5:0 F300
Ok
I did the mix ration but the G1 E5:0 F300 is running both extruders...
Tried selecting tool 1 and run G command but still both run together.
M563 P0 D0:1 ; Define tool 0
M567 P0 E4.0:1.0 ; MIXING RATIO
@cj-bravo That's odd - it works for me. Maybe it's because you have both extruders set to unity whereas I have a mixing hot end so the sum of all the extruders adds up to unity. Just guessing.
For now, you could define 3 tools. One as you have it now and the other two simply use just one extruder.
So as well as M563 P0 D0:1, also M563 P1 D0, and M563 P2 D1. No need to set mixing ratios for those other tools. Then selecting tool 0 will use both extruders, tool 1 will use extruder 0 and tool 2 will use extruder 1.
"set to unity" - what does that mean?
I'll try your solution if nothing else works,
Thanks!
unity = 1
