    BL Touch and Zero
    • WILLYD3113
      WILLYD3113 last edited by
      I've installed the BL Touch to my Duet and I'm running into a strange issue. I will manually zero the nozzle to the bed(G92 Z0) move up 10mm(G1 Z10) and do several probes(G30 S-1) and then input that value(for me is was like 4 mm) into the config under Z probe offsets. This is all well and good even up to a mesh bed probing, however printing is a different story. After all is said and done and I send the code G1 Z0, it will always hover 4 to 5 mm above the build plate and the same goes for printing. Ive tried everything from adjusting my start Gcode to changing the offset but to no avail. Here is my config. Thank You.
      ; generated by RepRapFirmware Configuration Tool v2 on Mon May 20 2019 16:13:32 GMT-0500 (Central Daylight Time)
      M550 P"PussySlayer" ; Set machine name
      M552 S1 ; Enable network
      M587 S"11818e" P"endless.955.drift" ; Configure access point. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S0 ; Physical drive 0 goes backwards
      M569 P1 S1 ; Physical drive 1 goes forwards
      M569 P2 S0 ; Physical drive 2 goes backwards
      M569 P3 S1 ; Physical drive 3 goes forwards
      M569 P4 S1 ; Physical drive 4 goes forwards
      M584 X0 Y1 E3 Z2:4 U4 P5 ; Apply custom drive mapping
      M350 X256 Y256 Z256:256 U256 E256 I0 ; Configure microstepping without interpolation
      M92 X1280.00 Y1280.00 Z6400.00:6400.00 U6400.00 E6790.00 ; Set steps per mm
      M566 X1800.00 Y1800.00 Z24.00:24.00 U24.00 E24.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z360.00:360.00 U360.00 E360.00 ; Set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z2040.00:2040.00 U2040.00 E500.00 ; Set accelerations (mm/s^2)
      M906 X1200.00 Y1200.00 Z1200.00:1200.00 U1200.00 E1200.00 I0 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X220 Y220 Z220 S0 ; Set axis maxima
      M574 X1 Y1 Z2 U2 S0 ; Set active low and disabled endstops
      M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
      M558 P9 H10 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
      G31 P500 X15 Y20 Z4.16 ; Set Z probe trigger value, offset and trigger height
      M557 X10:150 Y10:200 S30 ; Define mesh grid
      M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
      M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
      M106 P0 S1 I0 F500 H T10 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M563 P0 D0 H1 ; Define tool 0
      ; Custom settings
      M307 H3 A-1 C-1 D-1
      M558 P9 H5 F100 T2000
      G31 X0 Y0 Z0 P25
        Phaedrux Moderator @WILLYD3113 last edited by
        @willyd3113 said in BL Touch and Zero:
        ; Custom settings
        M307 H3 A-1 C-1 D-1
        G31 X0 Y0 Z0 P25
        You have a duplicate G31 entry at the end of your config file overriding your earlier line.
        • WILLYD3113
          Well, I feel kinda dumb, but thank you very much
