    Switched to 24v from 12v
    • vhoward
      vhoward last edited by
      I switched to 24v power supply from a 12v power supply. I got a 24v heater for the hotend and 24v fans all around. Everything was working before the change. Changed everything out and power up and everything except the part cooling fan works. I checked continuity of the wire and it is good. I changed out the connectors on both ends and still the fan will not work. I tried a second 24v fan and it won't work. I plugged the part cooling fan into the port for the hot end fan and set the hot end for 50c and when the hot end gets to 45c, the part cooling fan came on. So anything else I can check?
      • Veti
        Veti last edited by
        post your config
        • vhoward
          Here is my config.g file
          ; generated by RepRapFirmware Configuration Tool on Tue Oct 30 2018 18:17:49 GMT-0700 (Pacific Daylight Time)
          M667 S1 ; Select CoreXY mode
          M550 PV-King ; Set machine name
          M552 S1 ; Enable network
          M587 S"ssid" P"password" ; Configure access point. You can delete this line once connected
          M586 P0 S1 ; Enable HTTP
          M586 P1 S0 ; Disable FTP
          M586 P2 S0 ; Disable Telnet
          M569 P3 S1 ; Drive 3 goes backwards
          M92 X80 Y80 Z3200 E410 ; Set steps per mm
          M566 X600 Y600 Z24 E300 ; Set maximum instantaneous speed changes (mm/min)
          M203 X18000 Y18000 Z600 E1200 ; Set maximum speeds (mm/min)
          M201 X2000 Y2000 Z250 E2500 ; Set accelerations (mm/s^2)
          M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X300 Y300 Z340 S0 ; Set axis maxima
          M574 X1 Y1 S1 ; Set active high endstops
          M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
          M558 P9 H5 F400 T2000 ; Set Z probe type to bltouch and the dive height + speeds
          G31 P25 X25 Y0 Z0.280 ; Set Z probe trigger value, offset and trigger height
          M557 X40:285 Y15:280 S60 ; Define mesh grid
          M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
          M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
          M563 P0 D0 H1 ; Define tool 0
          M501
          I don't have a fan plugged into the 3rd pwm controlled spot.
          • Veti
            Veti last edited by
            connect the fan directly to the 24v power supply.
            if it is still not spinning then. then the fans are broken.
            • vhoward
              The second fan is working. But it won't work on "fan0". I am going to plug it into "fan2" and change the config for it to work as a part cooling fan and then tell my slicer to use fan2 for part cooling. For some reason the fan0 port quit working. I bought this board back before they started calling it duet2wifi.
              • Veti
                Veti last edited by
                you might have blow the fan mosfet for that header. this can happen when the fans are connected the wrong way.
                or since one of your fans isnt working it might have shorted the header.
                • vhoward
                  Yeah. It's a bummer. I have it working now on the fan2 header. Thanks for the input.
