    SOLVED Incorrect usage of G3 G4 arc moves?
    arc moves circular g3 g4
    • Nxt-1
      Nxt-1 last edited by
      I wanted to play around with making some demo movements scripts for the delta printer I am close to completing. As a start I wanted to do some circular moves (preferably helical, but I do not think those g-codes are implements as of yet). A quick look at the g-code documentation for arc moves leaves me to understand that if the head is currently located at X+100 Y0, the following g-code should result in a 180° arc move to X-100 Y0.
      G2 X-100 Y0 I0 J0
      My controller does not seems to agree with me though 🙂 Anyone know what is happening here?
      Duet3D and delta printer enthousiast. Buildlog
      Looking for Duet3D configuration support, check out Nxt-3D
      • A Former User
        you can't have both i and j 0 for an arc, maybe this helps https://www.cnccookbook.com/cnc-g-code-arc-circle-g02-g03/
        i.e. try
        G2 X-100 Y0 I0 J100 or G2 X-100 Y0 I0 J-100 for an upwards or downwards arc with respect to y?
        Nxt-1 1 Reply Last reply Reply Quote 1
        • Nxt-1
          Nxt-1 @Guest last edited by
          @bearer said in Incorrect usage of G3 G4 arc moves?:
          I see it now, I failed to realize that the I and J parameter are not absolute values.
