DOA Wifi Module???
  • I'm building a RailcoreII 300ZL kit I received earlier this week. Completed my wiring, passed my smoke test, but Duet 2 Wifi will not connect. I have latest firmware and latest Wifi firmware (DuetWiFiServer version 1.23 to the sys folder followed by a successful M997 S1 command), and can connect with USB through YAT. No success with any M558 commands. My M122 can be found below. Any help is much appreciated.
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later + DueX5
    Board ID: 08DGM-917DA-G4MS4-6J9D4-3S86R-19YVA
    Used output buffers: 1 of 20 (1 max)
    Static ram: 25524
    Dynamic ram: 98840 of which 0 recycled
    Exception stack ram used: 272
    Never used ram: 6436
    Tasks: NETWORK(ready,544) HEAT(blocked,1232) MAIN(running,3868) IDLE(ready,200)
    Owned mutexes:
    Last reset 00:01:47 ago, cause: power up
    Last software reset details not available
    Error status: 0
    Free file entries: 10
    MCU temperature: min 25.2, current 31.2, max 31.3
    Supply voltage: min 0.0, current 1.6, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
    Driver 0: ok, SG min/max not available
    Driver 1: ok, SG min/max not available
    Driver 2: ok, SG min/max not available
    Driver 3: ok, SG min/max not available
    Driver 4: ok, SG min/max not available
    Driver 5: ok, SG min/max not available
    Driver 6: ok, SG min/max not available
    Driver 7: ok, SG min/max not available
    Driver 8: ok, SG min/max not available
    Driver 9: ok, SG min/max not available
    Cache data hit count 262667517
    Slowest loop: 1.55ms; fastest: 0.06ms
    I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
    Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
    Scheduled moves: 0, completed moves: 0
    Bed compensation in use: none
    Heater 1 is on, I-accum = 0.6
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is ready with "M122" in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 1001.09ms; fastest: 0.00ms
    HTTP sessions: 0 of 8
    • WiFi -
      Network state is changing mode
      WiFi module is idle
      Failed to get WiFi status
      ok
      Error retrieving WiFi status message: bad reply format version
      WiFi module is idle
      WiFi reported error: no known networks found
    @jwalbridge said in DOA Wifi Module???:
    That state should not persist for more than a second or two. Please try copying the DuetWiFiServer 1.23 file to /sys again, rename it to exactly DuetWiFiServer.bin if it is called anything else (e.g. DuetWiFiServer-1.23.bin), restart the Duet, and run M997 S1 again.
  • I was able to connect after I disabled Beamforming Transmission(BFR) and Beamforming Reception(BFE) for the 2.4GHz signal on my router. I'm using a Nighthawk AC1900 Wifi Cable Modem Router. Was this likely the issue? Or did it just decide to start working? Did not have to run M997 S1 again.
    No, I don't think that was the issue. Try enabling beam forming again.
