SOLVED Heater fault issues
We are trying to heat a large surface area with a bed heater, and we are continually getting a heater fault or overshooting the temperature buy about 5 degrees. Would using PID to control fix this issue? Or should we continue to use Bang-Bang? If we continue to use bang bang what could we change to fix the issue.
Thankyou, Gregory
Why not just try the PID auto tune
https://duet3d.dozuki.com/Wiki/Gcode#Section_M303_Run_heater_tuning
Switch to PID and do an autotune as @bearer suggests.
What is the heater fault you are getting?
@bearer said in Heater fault issues:
Thank you for the advice, the machine is now working and has everything tuned.
