SOLVED Bed Temp Spike to 2000c when i home
I have had my printer running. Been trying to fine tune it etc.
However, yesterday i tried to print then realised, when i home the axis. My bed thermostat reads 2000 degrees. I haven't had this issue. I've unpluged the bed , checked the wiring and all seems good. Once I've homed it the temp continues to stay at the 2000cAnyone encountered this or got any ideas?
Thank you!
there is loose wiring that produces a short while moving.
@jackismad Bad connection due to a broken wire that only shows in a certain position. If it's constant 2000C, then a bad sensor and/or bad wiring. Use a multimeter to find it.
Thanks! I just found the bad wire. Its broke off the solder to the bed... Annoying but fixable! Thanks again
