    Using Duet WIFI with no WIFI connection
    • RodFord
      RodFord last edited by
      I have my machine at work and cannot connect it to wifi for security reasons. What is the best way to use it? The machine does have Paneldue. At the moment I am removing the SD card to install the print files.
        You can set it to access point mode and then use a device to connect directly to the Duet which creates its own access point.
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M589_Configure_access_point_parameters
          If the PanelDue is connected to the Duet via a ribbon cable (not the 4-way cable) then you can also use the SD card slot in the PanelDue to hold files to be printed.
          • A Former User
            A Former User last edited by
            While not sure what your exact security concern and policy is I would consider a wired ethernet connection to a Raspberry Pi running octoprint and a USB connection to the Duet Wifi.
            Mind you I haven't tried, but it is my understanding that Octoprint should work with the firmware if set to Marlin compatible mode but there are a few caveats.
            But if wired ethernet was an option I guess you would have gotten the Duet 2 Ethernet instead of the Wifi version?
            • RodFord
              Thanks for the replies. I will set up the access point option. This post is great. https://forum.duet3d.com/topic/3107/duet-wifi-in-access-point-mode
