    Z BABYSTEP - Increase steps?
    • CJ.BRAVOundefined
      CJ.BRAVO
      Can I increase the steps of the z baby step?
      instead of 0.05mm to 0.5mm or 1mm ?
        Yes. In the DWC under settings > User Interface > in the machine control box there is a setting for the amount of each baby step.
        However, if you're needing to use 1mm or more of baby stepping I think you have other problems which should be addressed.
        • CJ.BRAVOundefined
          CJ.BRAVO
          " I think you have other problems which should be addressed."
          you're absolutely right, see other post...
