    Dual bed heater configurations help
    • percarundefined
      percar
      Duel Bed Heaters
      I have a print bed 610mm X 305mm with 2 305mm X 305mm 110vAC attached to SSRs. Kapton heaters. I have searched this site for some direction on how to set the heaters to be controlled through RRfimware. In the documentation it states that up to 4 heaters can be controlled through RR firmware. What I am lacking is an understanding of the format to setup the heaters. I have been successful in turning on each heater however how do I setup them up so that I can control them at the same time. I would assume this should be as simple as a dual heater tool where when you set the temperature for the tool both heaters would be activated. The only way that I have been able to set them up is to use a macro turning on both heaters to a set temperature. If there is a format for turning on both heaters at the same time it would be greatly appreciated if you can share this. I need to know the initial setup for Config.g and any auxiliary settings that are required. One other item that I am having a problem with is to display both heaters for the bed on the duet web control.
      Thanks
      PN
        See https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M140_Set_Bed_Temperature_Fast. You need to use a different bed heater index for each heater. So use 0 for one of them and 1 for the other. Your config.g will look something like this:
        M140 P0 H0 ; first bed heater is on heater 0 output
        M140 P1 H3 ; second bed heater is on heater 3 output
        To set the temperatures:
        M140 P0 S55 ; set first bed heater to 55C
        M140 P1 S60 ; set second bed heater to 60C
        M116 ; wait for all temperatures
        Whenever you omit the P parameter, P0 will be assumed. The M190 command (set bed temperature and wait) can be used with a P parameter in a similar way, however you would normally want to wait for both to heat up at the same time, so M140 followed by M116 is better.
        • percarundefined
          percar
          Thanks David
          So there is not one command to turn on both heaters at the same time such as through the web control
            dc42 administrators @percar
            @percar said in Dual bed heater configurations help:
            Thanks David
            No, but you could set up macros to do that, one macro for each temperature of interest.
