    Fan channel help
    • Rendalsnikenundefined
      Rendalsniken
      Hello. I need help. I burned part cooling channel. how to assign another channel.
        You can connect the part cooling fan to the Fan2 output instead. Then add parameter F2 to your M563 command(s) in config.g. The effect of that will be that whenever a tool is selected, any M106 command with no P parameter will be routed to Fan 2.
        Rendalsnikenundefined 1 Reply Last reply Reply Quote 0
          Rendalsniken
          Like this
          M106 P2 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P1 S200 I0 F100 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
          M106 P0 S0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M563 P0 D0 H1 F2 ; Define tool 0
            Rendalsniken @dc42
            yes it works. thanks
