G29 P Parameter ignored?
Hey all,
Been struggling with this one for a few days and I've come to the conclusion either I'm doing something wrong or I've found a bug.
One of my printers is a modded CR-10S with a DuetWifi 1.04. I've tried both firmware 2.02 and 2.03 but get the same behaviour in both.
G29 seems to disregard the P parameter when probing a bed map. I've tried the following:
G29 S0 P"corners.csv" G29 S0 P"sys/corners.csv" G29 S0 P"/sys/corners.csv" G29 S0 P"0:/sys/corner.csv"
All of these commands overwrite heightmap.csv instead of creating corners.csv, confirmed by the console output:
G29 S0 P"0:/sys/corner.csv" 4 points probed, min error -0.018, max error 0.045, mean 0.013, deviation 0.025 Height map saved to file heightmap.csv
Issuing a G29 command to load a mesh map does seem to use the filename however:
G29 S1 P"0:/sys/corner.csv" Error: G29: Height map file 0:/sys/corner.csv not found
I temporarily overwrite my bed mesh definition to use the z-probe to level the 4 bed corners with the following macro:
G28 Z M557 X35:265 Y35:265 S230 ; Override current bed mesh G29 S0 P"corners.csv" ; Check the corners without overwriting heightmap.csv M557 X32:292 Y10:290 S32.5:35 ; Restore bed mesh
Is there something obvious I've missed, or have I found a bug?
Thanks! -
I am guessing that you have a BLTouch. You have found a bug. The P parameter won't work if you have non-empty deployprobe.g and/or retractprobe.g files.
Workaround: use G29 S0 to probe (and save to heightmap.csv), then use M374 to save to a file of your choice.
@dc42 said in G29 P Parameter ignored?:
Bingo!
Thanks @dc42, that'll work for now.
A quick side-note. Since upgrading to 2.03, the bed mesh doesn't seem to auto-show in DWC after a G29 anymore. Just noticed that when testing.
@nexxcat said in G29 P Parameter ignored?:
Is that DWC 1.22.6 or DWC 2.0RC? I thought that was a change in DWC (it works in 1.22.6, doesn't in 2.0RC).
Apologies, I'm running DWC 1.22.6.
Added to my list of things to test/investigate.
