2.03RC5 leveling issue
  • Since I installed 2.03RC5 builds after 2.02 I have an issue with leveling.
    Everytime i do a bed level it gives me a different height.
    -home, g32, m500
    Everytime a different height H*** (454, 461, 475, 480)
    Already calibrated the Z probe trigger height.
    Nothing to work....
    M111 S0 ; Debugging off
    G21 ; Work in millimetres
    M665 R234.295 L467 B197.5 H460 X-0.272 Y-0.589 Z0.000 ; Set delta radius, diagonal rod length, printable radius and homed height
    M666 X0.463 Y0.075 Z-0.538 ; Put your endstop adjustments here, or let auto calibration find them
    M208 Z0.1 S1 ; Set minimum Z
    M574 X2 Y2 Z2 S1 ; Set active high endstops
    M558 P1 X0 Y0 Z0 F150 H10 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
    G31 P500 X15 Y15 Z3 ; Set Z probe trigger value, offset and trigger height
    M557 R160 S15 ; Define mesh grid
    M581 T2 E1 S0 ; Endstop E0 EMERGENCY
    M569 P4 S1 ; Drive 4 goes forwards
    M92 X160 Y160 Z160 ; Set steps per mm
    ;M92 E883 ; Set steps per mm Titan bouden 1m
    M92 E844 ; Set steps per mm Titan flying ABS &PLA
    ;M92 E880 ; Set steps per mm Titan flying SBS
    M566 X1000 Y1000 Z1000 E800 ; Set maximum instantaneous speed changes (mm/min) (jerk) Голова может мгновенно разогнаться до скорости jerk (резкий срыв с места). Дальше начинается ускорение, которое задается acceleration
    M203 X12000 Y12000 Z12000 E7000 ; Set maximum speeds (mm/min)
    M201 X1500 Y1500 Z1500 E1000 ; Set accelerations (mm/s^2) Было по 3000
    M906 X2000 Y2000 Z2000 E800 I10 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    ;M572 D0 S0.25 ; Pressure advance
    M915 P0:1:2:3:4 S10 F1 H400 R1 ; Stall detection, R1 - log, R2 - pause
    M305 P0 T100000 B3950 R4700 ; Set thermistor + (H30 L0) ADC parameters for bed thermistor
    M143 H0 S130 ; Set temperature limit for heater 0 to 130C
    M305 P1 X200 ; Set thermistor parameters for heater 0 and remap it to channel 201
    M143 H1 S295 ; Set temperature limit for heater 0 to 280C
    M570 S190 ; Hot end may be a little slow to heat up so allow it 190 seconds
    ;M305 P100 X1000 ; Duet MCU temperature
    ;M305 P101 X1001 ; Duet WiFi drivers over temperature warnings. 0C when there is no warning, 100C if any driver reports over-temperature warning , and 150C if any driver reports over temperature shutdown.
    M563 P0 D0 H1 S"One" F0 ; Define tool 0
    G10 P0 X0 Y0 Z0 R0 S0 ; Set tool 0 axis offsets, active and standby temperatures to 0C
    M550 P**** ; Set machine name
    M551 P******** ; Set machine password
    M552 S1 ; Enable network
    M586 P0 S1 R8888 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M106 P0 H1 S0.7 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M106 P1 S0 I0 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P2 S0 I0 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
    T0
    M911 S21.0 R23.0 P"G91 M83 G1 Z5 E-5 F1000" ; auto-pause on loss of power
    M912 P0 S-0.3 ; CPU temp correct
    M501 ; Read stored parameters config-override.g
    ; config-override.g
    M665 L492.101:492.101:492.101 R241.165 H480.221 B197.5 X0.375 Y-0.156 Z0.000
    M666 X0.139 Y-0.272 Z0.133 A0.00 B0.00
    ; Heater model parameters
    M307 H0 A260.8 C1350.7 D9.8 S1.00 V24.5 B0
    M307 H1 A1086.4 C296.3 D8.0 S1.00 V24.5 B0
    M307 H2 A370.1 C211.2 D5.6 S0.50 V24.5 B0
    2.03RC releases are no longer supported, because 2.03 has been released.
  • there were some changes to leveling since the rc. please update to 2.03 release and try again.
    also why 0.1?
  • @dc42 ok, I'll try
  • @veti coz I print with 0.1 layer step
    If I set 0.2, first layer (with 0.1 layer step) very poor and don't catch on bed....
  • no you adjust the offset of your probe in the M558 command not with M208
  • Still not work!
    G32
    Calibrated 7 factors using 16 points, deviation before 9.727 after 0.077
    G32
    Calibrated 7 factors using 16 points, deviation before 0.436 after 0.055
    G32
    Calibrated 7 factors using 16 points, deviation before 7.144 after 0.063
    G32
    Calibrated 7 factors using 16 points, deviation before 6.261 after 0.092
    G32
    Calibrated 7 factors using 16 points, deviation before 11.004 after 0.046
    G32
    Calibrated 7 factors using 16 points, deviation before 15.613 after 0.078
    I suspect you are getting inconsistent results from probing. Try replacing S7 on your final G30 command by S-1 so that it prints the errors without making corrections. Then run G32 several times and see how consistent the results are.
    Also, we don't normally advise using 7-factor calibration unless the height map is a particular shape. 6-factor usually gives better results.
  • @dc42
    02:39:01G32
    G32 bed probe heights: -2.687 -2.702 -2.807 -2.825 -2.948 -3.058 -2.749 -2.889 -3.022 -2.864 -3.056 -2.895 -2.875 -2.700 -2.974 -3.005, mean -2.879, deviation from mean 0.122
    02:36:56G32
    G32 bed probe heights: -2.693 -2.696 -2.826 -2.850 -2.954 -3.071 -2.761 -2.895 -3.022 -2.858 -3.056 -2.913 -2.882 -2.706 -2.968 -3.005, mean -2.885, deviation from mean 0.121
    Those results show differences of around 0.02mm which isn't ideal, but not too bad. Try S6 instead of S7.
  • @dc42
    Did s6.
    Now G32 repeats little good....
    G32
    Calibrated 6 factors using 16 points, deviation before 0.132 after 0.106
    But before on 2.02 was be after 0.03-0.08(maybe because I did matte on my glass today)
    Thank you. I will try to print something tomorrow....
  • @dc42
    Now better, but not ideal (((
    Calibrated 6 factors using 16 points, deviation before 0.450 after 0.109
    Calibrated 6 factors using 16 points, deviation before 0.260 after 0.174
    Calibrated 6 factors using 16 points, deviation before 0.207 after 0.156
    Calibrated 6 factors using 16 points, deviation before 0.346 after 0.113
    Why this happening?
    First layer poor....some place the nozzle touching the bed some plase have pit...
    If I run G29 the nozzle starting print like on wave... and first layer much more poor .
    @spax, what type of Z probe do you have on your delta printer?
    After run G32 a few times, if you then run G29, what does the height map look like?
  • @dc42, I use your IR probe.
    22:32:26G29
    109 points probed, min error -0.158, max error 0.575, mean 0.214, deviation 0.150
    Height map saved to file heightmap.csv
    22:26:15G32
    Calibrated 6 factors using 16 points, deviation before 0.178 after 0.100
    22:25:04G32
    Calibrated 6 factors using 16 points, deviation before 0.239 after 0.095
    22:23:55G32
    Calibrated 6 factors using 16 points, deviation before 0.371 after 0.126
  • I have 6mm aluminium plate + 0.5 heatsink pad + 4mm glass (back side painted in black).
  • @dc42 any thoughts?
  • Moderator
    Can you rerun the G29 heightmap with a piece of plain paper covering the bed surface? The idea being to eliminate any inconsistencies in the IR probe reading the surface.
    Also please post a screen shot with the height map rotated so that we are looking along the X axis.
  • @dc42 @Phaedrux
    19:36:16G29
    97 points probed, min error -0.587, max error 1.307, mean 0.383, deviation 0.415
    19:28:00M500
    19:27:48G32
    Calibrated 6 factors using 16 points, deviation before 0.254 after 0.091
    19:26:43M500
    19:26:37G32
    Calibrated 6 factors using 16 points, deviation before 0.132 after 0.111
    19:25:31M500
    19:25:01G32
    Calibrated 6 factors using 16 points, deviation before 0.209 after 0.080
    19:23:54M500
    19:23:44G32
    Calibrated 6 factors using 16 points, deviation before 0.379 after 0.108
    That height map looks terrible, as if you are probing off the edge of the bed or something like that.
  • @dc42 Coz idea with paper is bad idea) Paper of sheet not 100% flat... 🤷
  • @spax said in 2.03RC5 leveling issue:
    That height map has high points "0.25mm of more" and low points "-0.25 or less." A sheet of paper isn't going to deviate in thickness by over 0.5mm!
  • @garyd9 @dc42
    that also because paper sheet was be not on all bed surface...I have bed dia 40cm, paper A4
    Time to get a bigger sheet of paper?
