    Solved Duet Wifi will not connect via web control
    Duet Web Control
    787
    • A Former User
      A Former User last edited by
      I just upgraded both of my printers to Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.03 (2019-06-13b2) . These are identical printers. One of them works no problem, the other however I can not connect via the web interface. If i plug in a usb I can go through all of the steps to set it up. But when I get to m552 S0 to turn off the wifi it just says SENDING:M S0, it does not say anything after that. So then I try the m552 s1 and it says TURN OFF THE CURRENT WIFI MOSE BEFORE SELECTING A NEW ONE. I have tried swapping my sd cards from one to the other but that does not help. I can ping my printer
        If you send M552 without parameters, does it say it is connected to your access point?
        You said you can ping it from your PC. Check that when the Duet is powered down, you can no longer ping it, in case you have an IP address conflict.
        What exactly happens when you enter the Duet's IP address in your browser?
        You can reset the WiFi module by sending M552 S-1. After that you should be able to send M552 S1 again.
        • A Former User
          @dc42 said in Duet Wifi will not connect via web control:
          M552 S1
          When I send the M552 command it just says WiFi module is being started.
          It never goes past that.
          When I ping it this what I get. The 192.168.1.92 used to be the ip for that printer, not sure wy it says 192.168.1.72 Destination host unreachable.
          I did try the M552 S-1 and then the M552 S1 command. It just says sending M552 S1....nothing happens after that.
          PS C:\Users\Richard> ping 192.168.1.92
          Pinging 192.168.1.92 with 32 bytes of data:
          Reply from 192.168.1.72: Destination host unreachable.
          Ping statistics for 192.168.1.92:
          Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
          A Former User 1 Reply Last reply Reply Quote 0
          • A Former User
            A Former User @Guest last edited by
            @chichirod said in Duet Wifi will not connect via web control:
            likely your computer (and its IP address) tellig you it cannot reach the printer/target
              I think you may be running an old version of Duet WiFiServer that is incompatible with the newer Duet2CombinedFirmware. Download DuetWiFiServer 1.23, put the SD card into a PC and copy DuetWiFiServer.bin into /SYS (it must be called exactly that on the SD card). Safely remove the SD card, put it back in the Duet, start the Duet, and send M997 S1 from USB or PanelDue to install it. Watch the installation progress messages to check that it is installed successfully.
              A Former User 2 Replies Last reply Reply Quote 0
              • A Former User
                A Former User @dc42 last edited by
                M997 S1
                Worked like a charm, Thank you I Love this board. Problem solved. Now back to printing!
                • A Former User
                  A Former User @dc42 last edited by A Former User
                  Hi DC42 sorry one more issue, now that I can connect via web control when I power on my printer my BLTouch no longer works. It just starts flashing and says G28 Z probe already triggered. It was working flawlessly before the update. Suggestions?
                    What firmware version were you using before the update? And can you post your config.g?
                    • A Former User
                      A Former User @Phaedrux last edited by
                      @phaedrux Hi here is my config.g file:
                      It was 1.21 but now its 2.03
                      ; generated by RepRapFirmware Configuration Tool on Thu Nov 08 2018 21:43:50 GMT-0700 (Mountain Standard Time)
                      M550 PRED Rodriguez Black Widow ; Set machine name
                      M552 S1 ; Enable network
                      M587 S"RCMP Surveillance 2.4" P"241428433" ; Configure access point. You can delete this line once connected
                      M586 P0 S1 ; Enable HTTP
                      M586 P1 S0 ; Disable FTP
                      M586 P2 S0 ; Disable Telnet
                      M92 X80 Y80 Z1600 E415 ; Set steps per mm
                      M566 X420 Y420 Z20 E120 ; Set maximum instantaneous speed changes (mm/min)
                      M203 X10000 Y10000 Z1200 E1200 ; Set maximum speeds (mm/min)
                      M201 X1000 Y1000 Z20 E500 ; Set accelerations (mm/s^2)
                      M906 X1100 Y1100 Z1200 E400 I30 ; Set motor currents (mA) and motor idle factor in per cent
                      M84 S30 ; Set idle timeout
                      M208 X370 Y241 Z400 S0 ; Set axis maxima
                      M574 X1 Y1 S0 ; Set active high endstops
                      M574 Z1 S0 ; Set endstops controlled by probe
                      M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
                      M558 P9 F200 H3 R0.2 T12000 A5 B0 ; Set Z probe type to bltouch and the dive height + speeds
                      G31 P25 X-11 Y57 Z0.4
                                                   ; Set Z probe trigger value, offset and trigger height
                      M557 X10:370 Y10:240 S60 ; Define mesh grid
                      M305 P0 T100000 B4725 C0 R4700 ; Set thermistor + ADC parameters for heater 0
                      M305 P1 T100000 B4388 C0 R4700 ; Set thermistor + ADC parameters for heater 1
                      M563 P0 D0 H1 ; Define tool 0
                      ; Automatic power saving
                      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                      G1 Z0 F6000 S2 ; lower Z again
                      M564 H0
                      T0 ; Select first tool
                        dc42 administrators @Guest last edited by
                        A flashing BLTouch means it is in an error state. There is an M280 command that you can send to reset it.
                        When does it start flashing: the first time the firmware tries to deploy it, or at some other time?
                        If you have any M401 or M402 commands in any of your homing of bed probing files, remove them. Likewise any M98 commands that invoke deployprobe.g or retractprobe.g.
                        • A Former User
                          @dc42 Hi, its starts flashing within 5 seconds of turning the power on. I had no M401 or M402 codes but I did delete the M98 command. I still have the same thing. Within in seconds of powering up it starts flashing
                            what does it do if you send the servo command to clear the error state and retract the probe?
                            M280 P3 S160 I1
                            • A Former User
                              @phaedrux said in Duet Wifi will not connect via web control:
                              M280 P3 S160 I1
                              That seems to have fixed. Ill play with it for a bit but it seems perfect now. Thank you
                                At power up the probe does it's self test where it drops and retracts the pin a few times to get that it's working. If the pin gets blocked somehow it will error out.
                                Does the pin actually drop and retract? Is it far enough away from the bed to do so?
                                I've added M280 P3 S160 I1 to the end of my config.g to clear any errors. It was left over from original testing and I never removed it. If the probe seems to work otherwise, and clearing the error seems to work, maybe you could add it to config.g as well.
                                • A Former User
                                  @phaedrux It seems to work fine now but I might just do that anyways. Thanks again
                                    I'm marking this as solved, because the original problem in the title is.
