whish for Adjust Z Axis with 2 independent Z-Motors
  • Hello,
    for now this funktion works so far but i have to messure up to 8 times to get a even printbed sometimes i need only 4 times to reach a good calibration. Now is my Idea to define once in bed.g the calibration settings like this:
    G30 P0 X10 Y190 Z-99999 ; Sonde in der Nähe einer Leitspindel auf halbem Weg entlang der Y-Achse
    G30 P1 X380 Y190 Z-99999 S2 ; Sonde in der Nähe einer Leitspindel und 2 Motoren kalibrieren
    and after that it where great if there was a command with which you could adjust how often maximum is measured and you could specify that if value x or smaler is reached that the measurement will be terminated. like this example
    g35 M7 r0.01 ;do the G30 Block 7 times max or until the bed has reached 0.01mm or smaler
    i think this function would be great
    That will be possible when conditional GCode is fully implemented in RepRapFirmware 3.
    Why is it taking up to 8 iterations of G32 to get the bed level? Please share the output from running G32 several times.
  • @dc42 said in whish for Adjust Z Axis with 2 independent Z-Motors:
    that would be great!!
    as soon as my printer has finished printing but that still takes a while
  • sorry for the long delay! I have now made a few optimizations on my Hotend and Orion mount, since then I only need 2 max 4 passes for a reasonable result! an now i hope the "G35" funktion will find the way to RRF 3.xx 😀
    @siam, if you find that each time you run G32 it under-corrects, you can use the M671 F parameter to force some over-correction, to help it to converge faster. For example, F1.5 will apply 150% of the computed correction.
