    Having trouble connecting motors to Duex5
    • p40whkundefined
      p40whk
      I've got a Duex5 connected to my Duet WiFi2 and am using Drive 5 and 9 for my X and Y motors and drives 6,7,and 8 for a three leadscrew Z-axis on the Duex5. Everytime I try to home either axis using home all or individually the Z-Axis moves (only drive 7) and I get no movement out of my other drives.
      This is how they are setup in my config.g:
      M569 P0 S1 ; Physical drive 0 goes forwards
      M569 P1 S1 ; Physical drive 1 goes forwards
      M569 P2 S1 ; Physical drive 2 goes forwards
      M569 P3 S1 ; Physical drive 3 goes forwards
      M569 P4 S1 ; Physical drive 4 goes forwards (Extruder)
      M569 P5 S1 ; Physical drive 5 goes forwards (Y-Axis)
      M569 P6 S0 ; Physical drive 6 goes backwards (Z-Axis)
      M569 P7 S0 ; Physical drive 7 goes backwards (Z-Axis)
      M569 P8 S0 ; Physical drive 8 goes backwards (Z-Axis)
      M569 P9 S1 ; Physical drive 9 goes forwards (X-Axis)
      M584 X9 Y5 Z6:7:8 E4 ; Three Z motors connected to driver outputs 6,7,8 Drive 5 controls X, Drive 9 Controls Y, Drive 4 controls E
      ; Motor order: Left (1), Right (2)
      I am also getting the following error:
      Warning: motor phase A may be disconnected reported by driver(s) 6 7 8
      Warning: motor phase B may be disconnected reported by driver(s) 6 7 8
      I am using the standard cables that came with the steppers so not sure if the wiring is correct for the Duet as I haven't put a meter on them.
      Just wondering where I should begin troubleshooting as I'm not sure what is causing this, any help would be appreciated,
      Thanks
      • deckingmanundefined
        deckingman @p40whk
        @p40whk You need to explicitly assign all drivers - see the warning here https://duet3d.dozuki.com/Wiki/Gcode#Section_M584_Set_drive_mapping
        So if you are not using drivers 0,1 ,2 and 3, make them extruders. i.e. M584 X9 Y5 Z6:7:8 E4:0:1:2:3.
        Just out of curiosity, what is the reason for not using drivers 0 to 3?
        • p40whkundefined
          p40whk
          Thanks Deckingham, I did not realize I had to assign the unused drivers.
          The reason I was not using 1-3 was more of a location and wire routing decision. Most of the stepper motors are close to the Duex5 so I have shorter wire runs and cleaner wiring. I also planto add additional extruders in the future so I will use those at a later time.
          I did put a meter on my motors and verify that they are wired right, I also ran the check stepper motor test here [https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Checking_connected_stepper_motors](link url) And it is definitely the Z motors that are giving me the trouble.
          I try assigning the other motors and see what that does,
            Actually, you should not need go assign unused drivers. What you do need to do is reassign the extruders because drivers 5 to 9 default to being extruders; but you were already doing that.
            I suggest you use your multimeter to check the resistance between pairs of motor pins at the Duet end of the motor cables.
            Make sure that your M350 and M906 commands are later in config.g than the M584 command.
            • p40whkundefined
              p40whk
              Thanks dc42, I went back in and did the reassignment of the drives and it seems to be working however I could not get the X or Y axis to home. It was late and I was falling asleep so I didn't get a chance to troubleshoot.
              I did use a multimeter and checked the resistance of motor pairs and that wasn't an issue, and my M350 and M906 commands do come after the M584.
              Just need to figure out why the X an Y axis won't home and I'll be happy. Using the procedure linked above, X and Y both move in the correct directions but there must be something wrong with my Home files preventing them from working right.
                deckingman @p40whk
                @p40whk Glad you are making progress. If you are still stuck, post your entire config.g and homing files here.
