    Error: short-to-ground reported by driver(s) 2
    1.0k
    • eric22mundefined
      eric22m
      I transferred to a duet WiFi 2 a few months ago and I have been loving it. After setup, my printer has worked flawlessly. But today when I attempted to home the machine I was greeted with a short-to-ground error. The motors make a sound just like its binding. I have narrowed the issue to my z stepper motors. What is the issue and how can I fix it. I have attached a screenshot of the error:0_1561157772467_64782087_2371128069837294_4886680782841577472_n.jpg
      • Vetiundefined
        Veti
        first check the wiring and crimps.
        use a multimeter to measure the the resistance of each wire.
        then measure the resistance of each phase of the motor.
        eric22mundefined 1 Reply Last reply Reply Quote 0
        • eric22mundefined
          eric22m @Veti
          @veti How would I measure each phase of the stepper motor?
          • Vetiundefined
            Veti
            measure the resistance between the pin/cable of red/blue and green/black
              It could be faulty wiring, a faulty stepper driver chip, or a faulty motor. Is there any sign of damage to the Z driver chip?
              • eric22mundefined
                eric22m @dc42
                @dc42 I tried to use a completely new stepper with different wiring as well but I still get the same error. The stepper driver looks completely fine.
                • eric22mundefined
                  eric22m @Veti
                  @veti I checked the resistance of the wires and everything seems normal.
                  • Vetiundefined
                    Veti
                    reconfigure the E1 output to be Z to be sure.
                    https://duet3d.dozuki.com/Wiki/Gcode#Section_M584_Set_drive_mapping
                    M584 X0 Y1 Z5 E4
                    • eric22mundefined
                      eric22m
                      I believe the issue is the stepper driver. I have contacted the company I bought it from and they have agreed to send me a new board. Thank you all for your help.
