Help with custom firmware settings for Rostock Max V2 upgrade
  • Hey all! So... I finally bit the bullet and decided to upgrade from my Rambo and make my Rostock all it can be. 🙂
    So, to start, My V2 is already kind of a Frankenstein build. After this upgrade the only think stock on it will be the frame and belts! lol
    I should have most of my parts by this weekend and thought I'd get started on setting up the firmware ahead of time (as best as I am able without parts in hand, anyway). At the end of the weekend my printer will have the following parts installed.
    Starting from the ground up:
    Duet 2 Wifi
    0.9 Degree Stepper motors (Used on V3.2)
    700 watt PC grade PSU supplying 12 V
    SSR supplying 24V from a second Powersupply for Bed Heat
    GeckoTek Aluminum Heatspreader and Magnetic Flex plate build surface
    SeeMeCNC Injected Carriages
    SeeMeCNC Carbon Fiber Ballcup Arms (340.5mm)
    Duet Delta Smart Effector (adapters used to fit the SeeMeCNC Barbells)
    e3D Titan Extruder (using stock Wantai 42BYGHW811P2 Stepper Motor... Calibrated to 405.99 steps/mm)
    Capricorn 1.8mm bowden tubing
    e3D v6 Hotend with MicroSwiss Heatbreak, e3D Copper heat block, 40w 12v heater.
    e3D PT-100 and Duet PT-100 Daughterboard
    That's about it. geneb, over on the SeeMeCNC forums suggested using the Rostock Max V4 firmware as a starting point. I can see why, as much of it will apply to my build, with the main differences being related to the Extruder, Hotend/Pt-100, and Smart Effector.
    I guess my main questions are:
    1.) Should I still use the Reprap Online Configurator and just transpose values and new settings over via that or just make the few changes I need manually to the V4's firmware? Any advice on specific changes to pay attention to?
    2.) Is the Config .g file the only one I need to modify for my build?
    I know I'll have further questions, but those will probably be trouble shooting and tweaking related. Just hoping to get a basic starting point down that won't completely break the machine the second I try it out. 🙂
    Thanks all!
  • Ok, I went through the online configurator again. This time I pulled data from the Rostock Max V4 config.g file (and a few spots in my current repetier firmware pertaining to endstops, extruder calibration, and stepper directions).
    I've attached a copy of the config.g (wifi data removed) 😉
    So, my next round of questions.
    1.) Should I be using the full rated amperage listed on the stepper motors or setting them to something lower? My 0.9 degree motors will be 1680 mA. The V4 (I'm pretty sure) has 2000 mA motors, but is running them at 1400mA. ( I also just went ahead and plugged in the values listed for the V4's speed and acceleration, since that's kind of starting point anyway.)
    2.) The V4 is still using 16x microstepping on the motors. Is this just something most users eventually adjust up to 32x microstepping after getting everything properly calibrated or is there a specific reason for leaving it at 16x in the case of a delta?
    3.) When it came to Bed probing and the homing boxes, I just left everything at default. Should I change any of these now, or just wait till I have everything working after a couple of basic calibrations?
    4.) Network settings: Is there any practical reason why I would want to enable FTP or Telnet? I assume anything you would use those for is also handled through Duet Web control, correct?
    Anyway, If someone familiar with the Rostock Max (and or anything similar to what I've got hardware wise) could give it a look over and steer me clear of any potential errors, I'd be might grateful! Thanks 😀
    0_1561445313727_config.g
    1. see https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors
    So the usual practice is to set the motor current to no more than about 85% of the rated current
    1. The duet wifi only supports interpolation at x16. the motors will be a lot quieter with that. At the moment you have disable interpolation
    2. Do a Test print and see how the first layer looks.
    3. if you dont need ftp or telnet there is no reason to enable it.
  • @veti said in Help with custom firmware settings for Rostock Max V2 upgrade:
    I'd seen that document earlier, but it makes a lot more sense now. I've gone back and set it up for 16x (on) in the configurator. Figure 1.2A is a good starting point for my chosen motors. I downloaded the spreadsheet linked in the wiki page and ran the numbers for my steppers (which were pretty close to the defaults in the spreadsheet). I really don't care so much about the stepper noise since I have my printers in a fairly large shop area where it isn't a factor. I'm assuming 16x interpolation is better than just running it at 256x, or somewhere in between, for other reasons than just noise?
    As far as stepper Max Speed goes, the spreadsheet shows me a worst case speed of around 125mm/sec (just about spot on with the V4's stock steppers) @ 12V. The V4 firmware shows a max speed of 250mm/sec. Is the general rule of thumb to just double it and plan to print slow near the edge of the plate?
    I see I can gain over double the speed by going to 24v. What would you suggest for a Max speed in the firmware at 24v?
    On the subject of 24v, I was planning on keeping it at just 12v to match my current PSU and hotend, but for a few $ I can easily get a 24v heater cartridge and it's not that spendy to just get a good AC Silicone heating pad for the heatbed. I've got a spare 240 watt 24v/10A psu that came stock with my Prusa Mk3. Assuming I run the heatbed off from the AC mains, would 240 watts be sufficient to run my steppers, extruder, 40 watt hotend, and duet3d/fans? I estimate at max Amps on all the motors and hotend I'd be drawing around 9A, leaving me 1A for the board/fans/etc. If I'm running the steppers at the 1.2A I currently have them set, it comes down to around 6.5 +board/fans/etc... Is that Enough acceptable headroom to be safe and sufficiently powered?
    I'm already over budget on what I was going to do for an upgrade, but at this point, a little bit extra to go full 24v with an AC heatbed seems to be a much more practical choice (especially since I'll have the whole printer tore down for the switch over anyway). If I can use the PSU I have on hand, however, that would save me a few $ and make me feel a bit better about it. 😁
  • @metallikahn said in Help with custom firmware settings for Rostock Max V2 upgrade:
    more steps will require more cpu resources. on a delta this could become more problematic at high speed.
    If you want more accuracy, 0.9 degree steppers are the way to go.
    It depends also on the weight of the effector and the acceleration settings. Easiest thing is to try and if you get layer shifts reduce speed or acceleration.
    At 125mm/sec you could be limited by your hotend. Higher speed will certainly require something like a volcano hotend.
    Fans are also voltage specific. 240 watt without heated bed is plenty.
    See
    https://duet3d.dozuki.com/Wiki/Choosing_the_power_supply
    Ok, now that you say that, I seem to remember reading that a year or two ago. Basically 16x interpolation with .9 steppers gets you the improved motion you might expect from a higher microstepping with 1.8 degree steppers and also saves on the Processing power.
    Yep. The speed concern was mainly for a safe setting in the firmware. Very rare that I use an actual print speed in excess of 60 mm/s. The hotend and smart effector will be the only weight hanging in the middle to start. Depending on how the Titan performs in the new setup, I might persue a remote drive extruder like the Nimble in the future... (so still not much of a factor.
    See
    Excellent! I missed that article while browsing earlier. Not too worried about the fans since e3d has lots of 24v fan options and I'll be building a custom layer fan anyway. Looks like if I just grab an AC Silicone Heater pad, a 24v heater cartidge and a couple of 24v fans I should be good to go!
    Thanks for the help! I feel like I got a much better handle on how this is going to come together now. 🤘
    My delta isn't a Rostock, but it has a 300mm diameter printable area, 360mm rods, 24V power, and 0.9deg 1.68A motors. It can do 250mm/sec travel speeds. It can't quite manage 300mm/sec at the edges of the bed using my standard acceleration settings.
    It's better than that. 0.9deg motors give you nearly twice the torque per unit angular error than 1.8deg motors, so you get better resolution. Whereas increasing microstepping from x16 to x32 typically doesn't improve resolution, because of the drop in incremental torque per microstep.
    Don'r forget that you also need a DC-AC SSR to control an AC bed heater.
  • @dc42 said in Help with custom firmware settings for Rostock Max V2 upgrade:
    I'm shooting for between 300-304 (Over 304mm and the ballcups Juuuust touch the belts!) 😬 printable with SeeMeCNC's 340.5mm Carbon fiber arms. Can just manage 300 with the 290mm arms I currently have, but it's really hit or miss and the steppers are definitely slipping by that point. Definitely looks like 24V is the way to go. That'll give me a near identical hardware setup as yours in that particular area. As I mentioned, I rarely use a print speed over 50-60mm/s (even with a .6-.8 nozzle), but if it can handle that kind of speed it should really do a great job on the lower speeds for me, which is exactly what I'm after! 😀
    It's better than that. 0.9deg motors give you neatly twice the torque per unit angular error than 1.8deg motors, so you get better resolution. Whereas increasing microstepping from x16 to x32 typically doesn't improve resolution, because of the drop in incremental torque per mitostep.
    I've been looking at doing the .9 upgrade as long as I've been eyeballing the Duet wifi upgrade! Always assumed the two should go hand in hand. If increased microstepping ends up being a wash on results, then x16 interpolating is definitely the way to go! ☺
    Got exactly that coming. Was going to use it to boost my Stock bed to 24v, but the AC heater makes a lot more sense and frees me up a whole 24v supply to run everything else.
    Grabbed an e3D 24v 40W Precision heater (should pair well with my pt-100!) a 24v fan for the hot end, and figured... as long as I'm swapping steppers, I might as well go all out and drop in a set of Astrodyn Dampners while I'm at it. This might not be the greatest Rostock Max V2 ever, but It's still gonna be one helluva machine! 😁 🤘
    Still researching for a good silicone heater that will sit/mount flat between my aluminum spreader and Onyx build plate. Keenovo shot me a quote for $76 delivered on a custom designed (with precut screw holes) 305mm 400 watt AC heater that came with a preinstalled PT-100 sensor and centrally located wires. ( I'd have to cut and enlarge the Onyx hot bed's center hole, but at that point I'm just planning on using it as an insulator for the wood frame anyway.) Only issue is it might take upwards of 4-8 weeks to arrive. For and extra $30, I might be able to get it in 3-4 weeks. As cool and well priced as the custom design is, a 280mm disc would pobably do the same job just as well. I've got them running me a quote on an off the shelf 280mm plate and throwing in a PT100 sensor for me to self install. If it's not too bad, I'll probably jump on it. 🙂
    You need different types of SSR depending on whether the bed heater is low voltage DC or mains voltage AC.
  • Moderator
    Don't forget that to use a PT100 you will need the daughter board.
    👍 got one specc'ed exactly the same as SeeMeCNC sells for running their AC heaters. 😉
  • @phaedrux said in Help with custom firmware settings for Rostock Max V2 upgrade:
    Yep! Included in my first post. Just some of the many $ I've spent with Filastruder in the last couple weeks! 🤣
