    CoreXY confusion.... Please help me understand
    • Steve Lynchundefined
      Steve Lynch
      Ok, I'll try to be as concise as possible, and ask my questions one at a time.
      I converted My FT-5 to a CoreXY with My Duet 2 Wifi from Filastruder, and My new Chimera (also from Tim! Thanks Bro!)
      My Alpha Motor, which I assume is P0 is plugged into the X axis. It is on the left front (towards me when standing in front of it)
      My Beta Motor is Plugged into what I assume is P1 is plugged into the Y axis.
      My Alpha and Beta Motors are mounted upside down.
      I want my Home Position to be front Left
      Y endstop is in the rear left Plugged into "Y stop" port
      X endstop is on the left side of the X carriage Plugged into "X stop" port.
      I have firmware 2.03
      I have M669 K1 defined
      When I move Either X or Y, only one motor turns, moving the head diagonally.
      I have tried every combination of reversed directions I can, and can neither get both motors to move, nor can I get Positive movement on either axis to respond as expected. No matter what, X Moves left when I move it in the + direction. I want travel to the right to be +
      On the Y, +Moves the axis towards the front. I want the Rear of the machine to be +
      I've read the wiki 10 times, but it's extremely confusing.
      Could you clarify a couple things?
      End stop "High" does this mean the "max" end of the axis? and Conversely, "low" the "Min"?
      Which "P" designations correspond to the ports on the board? They're called E1, E2, X, Y, Z on the board itself, but are referred to as "P" in the firmware. what are the "P" numbers for the corresponding ports please? I can't seem to find any diagram of this anywhere.
      Thanks so much! I bought a second Duet for a Wanhao upgrade, and it went flawlessly, as I finally got cartesian setup dialed in. This corexy business seems to have 800 experts on the subject all of whom have a different reason to tell me why I'm doing it wrong. Here's My Config.G I'm still in the middle of playing with direction, so it's probably all out of whack in that respect.
      One last thing, I keep getting an error (Photo attached)
      I'm so sorry for such a lengthy post, but I've tried to do it myself, and I'm fried!!
      ; generated by RepRapFirmware Configuration Tool v2 on Mon Jun 24 2019 21:07:24 GMT-0400 (Eastern Daylight Time)
      M669 K1 ; Select CoreXY mode
      M550 P"FT-5 COREXY" ; Set machine name
      M552 S1 ; Enable network
      M587 S"Lynch WiFi" P"internet" ; Configure access point. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S0 ; Physical drive 0 goes forwards
      M569 P1 S1 ; Physical drive 1 goes forwards
      M569 P2 S1 ; Physical drive 2 goes forwards
      M569 P3 S1 ; Physical drive 3 goes forwards
      M92 X80.00 Y80.00 Z400.00 E410.00 ; Set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; Set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
      M906 X800.00 Y800.00 Z800.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X300 Y300 Z0 S1 ; Set axis minima
      M208 X0 Y0 Z400 S0 ; Set axis maxima
      M574 X1 Y2 S1 ; Set active high endstops
      M558 P1 H5 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
      M557 X15:280 Y15:280 S20 ; Define mesh grid
      M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
      M106 P0 S0 I0 F500 H T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 S"Volcano" D0 H1 ; Define tool 0
      G10 P0 X0 Y0 Z10 ; Set tool 0 axis offsets
      T0 ; Select first tool
        Have you tried individual motor omvements as described in https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Movement_section ? Specifically, the part starting "Then test for the correct X motor movement by sending these commands from the console".
        The "Motor phase may be disconnected" messages indicate that you tried to move the motor connected to the E1 output (which in your configuration defaults to the second extruder drive) but you don't have a motor connected to it.
        • deckingmanundefined
          deckingman @Steve Lynch
          @steve-lynch
          Do what DC said but ....you've defined the axes minima and maxima reversed for X and Y.
          "; Axis Limits
          The minima should be 0 and the maxima 300 for X and Y (your Z is OK).
          To clarify your questions. End stop high end means the far end of the axis, low end is min. That is defined by "nnn" after the axis name (0 means no end stop, 1 means at the low end of the axis, 2 means at the high end of the axis). But don't get this confused with "active high" and "active low". That's the "S" parameter which, if you are using simple switches will be either 1 or 0 depending on if you've wired them normally closed or normally open.
          Yes, if the motors haven't been re-mapped using M584 then the default is that X is P0, Y is P1, Z is P2, the first extruder (E0) is P3 the second extruder (E1) is P4. (and yes, it can be confusing).
