    Remapping Z axis - troubleshooting
    • JThunderLoC
      JThunderLoC last edited by
      I have a duet wifi 2 that I've been using for a few months now and the prints have been fantastic. Everything had been dialed in tight and right up until about a month ago. I'd like to remap my Z axis to the spare extruder driver. When I set the Z axis to E1 in RRF I can control the axis and everything works, except I my extruder (E0) no longer works. How do I fix this?
        dc42 administrators @JThunderLoC last edited by
        Check that you have this M584 command in config,g:
        M584 X0 Y1 Z4 E3
        and that any M350 and M906 commands are later in config.g then that M584 command.
        • JThunderLoC
          I checked the config.g file and it does show M584 X0 Y1 Z4 E3; apply custom drive mapping
          The next line is the M350 and a few lines down is the M906. What else can I check?
          • JThunderLoC
            Here's a dump of config.g file
            ; generated by RepRapFirmware Configuration Tool v2 on Mon Jun 24 2019 19:38:23 GMT-0700 (Pacific Daylight Time)
            M550 P"My Printer" ; Set machine name
            M552 S1 ; Enable network
            M586 P0 S1 ; Enable HTTP
            M586 P1 S0 ; Disable FTP
            M586 P2 S0 ; Disable Telnet
            M569 P0 S0 ; Physical drive 0 goes backwards
            M569 P1 S1 ; Physical drive 1 goes forwards
            M569 P4 S0 ; Physical drive 4 goes backwards
            M569 P3 S1 ; Physical drive 3 goes forwards
            M584 X0 Y1 Z4 E3 ; Apply custom drive mapping
            M92 X80.00 Y80.00 Z2560.00 E407.00 ; Set steps per mm
            M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
            M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; Set maximum speeds (mm/min)
            M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
            M906 X800.00 Y800.00 Z800.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X-33 Y-12 Z0 S1 ; Set axis minima
            M208 X230 Y210 Z200 S0 ; Set axis maxima
            M574 X1 Y1 Z1 S1 ; Set active high endstops
            M558 P0 H5 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed
            M557 X-18:195 Y3:195 S20 ; Define mesh grid
            M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
            M563 P0 H1 ; Define tool 0
              @jthunderloc said in Remapping Z axis - troubleshooting:
              Your tool 0 is defined as not using any extruders.
              • JThunderLoC
                Ah, ok. What should I set it to? 3?
                  Add D0 to that M563 command to have tool 0 use extruder drive 0.
