    I'm confused about an entry in Dozuki re connecting FSR boards
    • ultibots58undefined
      ultibots58
      This is the entry I don't know how to interpret:
      " If using JohnSL's trinket board: Connect its Vcc, Output and Ground pins to 3.3V, IN and GND on the Z-probe connector respectively and select mode 5. "
      The 3 pins In the corner (under the rectifier ) of the John FSL board are labelled :
      Signal , -/+ , +/-
      Is Vcc = +/-
      Output = Signal
      Ground = - / +
      Thanks for any help
      • A Former User?
        A Former User
        Vcc is normally + and Gnd is normally - but this board features a rectifier on the power input you can connect them any way around, thus the +/- & -/+ notation which can be a bit confusing. But yes, you can connect it as you have laid out.
          ultibots58
          bearer ,
          thank you for the prompt confirmation. I went ahead after receiving your reply and it all works
          In case anybody refers to this thread:
          On JohnSL board Signal pin is connected to Z_Probe_In pin on Duet
          On John SL board +/- pin is connected to +3.3V on Duet
          On JohnSL board -/+ pin is connected to GND on Duet
          and in the config .g file for my delta printer is the following
          M558 P5 X0 Y0 Z0 H5 I1
          P5 and I1 being the important varaiables
          Thanks again
