    Load and unload
    • 3dware
      3dware last edited by
      Hello RC42
      Again, I have a question:
      If one of the 4 extruder triggers runout sensors goes into break, this is so far synonymous io, only if I then unload my load and macro launches he loses on the remaining extruders, the temperature and then prints with only one.
      How can I handle this, so that the tool always remains active before the break.
      Enclosed my load macro.
      Then I can pack the whole thing in a macro that when I load for example t4 (4 extruder) he only takes these which are also plugged?
      The rest then have a temp mistake.
      Do I have a possibility?
      I politely ask for help.
      regards
      Michel
      T91
      G91
      G1 Z5 F400
      G90
      G1 X0 Y-250 F800 ; Move to service position
      G10 S240 ; Set current tool temperature to 240C
      M291 P"Warten bis das Hotend 240°C erreicht hat!" R"Filament laden" S0 T600 ; Display message
      M116 S5 ; Wait for the temperatures to be reached
      G4 P200
      M300
      G4 P2000
      M292
      M291 P"Temperatur erreicht" S2
      M291 P"Bitte Filament einführen, halten und mit OK bestätigen" S3 ; Display new message
      M291 P"Führe Filament zur Düse" S0 T40
      G1 E10 F180 ; Feed 1870mm of filament at 3000mm/min
      G1 E40 F500 ; Feed 1870mm of filament at 3000mm/min
      G4 P1000 ; Wait one second
      G1 E100 F200 ; Feed 80mm of filament at 300mm/min
      G1 E-2 F500 ; Retract 10mm of filament at 800mm/min
      M400 ; Wait for moves to complete
      ;play sound
      G4 P200
      M300
      G4 P2000
      M400
      M291 P"Filament laden abgeschlossen bitte bestätigen mit OK" S2 ; Display new message
      M292 ; Acknowledge message
      unload:
      T91
      G91
      G1 Z5 F400
      G90
      G1 X0 Y-250 F800 ; Move to service position ; Move to service position
      M291 P"Bitte warten bis das Hotend 240°C erreicht hat!" R"Filament entladen" S0 T600 ; Display message
      M116 ; Wait for the temperatures to be reached
      M292
      M291 P"Entlade Filament..." R"Filament entladen" S2 ; Display another message
      G1 E30 F180 ; Load 30mm of filament at 180mm/min
      G1 E-150 F1000 ; Retract 200mm of filament at 1000mm/min
      M400 ; Wait for the moves to finish
      ;play sound
      G4 P200
      M300
      G4 P2000
      M291 P"Filament kann nun entfernt werden" R"Filament entladen" S2 ; Display another message
        @3dware, did you solve this problem? If not, please provide more details of your machine and the config.g file. Does it have 4 separate nozzles, each with one heater and one extruder, or a single nozzle with one heater and four extruders feeding it? Or something else?
