    G92 not setting virtual extruder position
    • Mekalaundefined
      Mekala
      My hot end clogged when I printing and I realize it after 30 minitues and I wanted to resume print from last layer,I editted the gcode and added T0 G92 E2389.98580 (which is my virtual extruder position) command to start. But when I resume printing from last layer the print head goes over the print and then it starts extruding all the way from 0 to the that value.
      How I set virtual extruder position
        Put the commands on separate lines. A T command may not be followed by other commands on the same line.
