Duet Maestro Ethernet not working
Are there methods on debugging the Ethernet port of the Duet Maestro? I think mine came in dead from Filastruder but I want to make sure just in case I missed something.
Thanks,
Rehuel -
Look at the LEDs on the Ethernet connector. When the Duet is connected to a router, and you have enabled networking using M552 S1, they should flash regularly.
If they do flash but you still can't connect, you can use Wireshark to sniff the Ethernet bus.
