    DUET3D WIFI AP MODE EEPROM PASSWORD
    • dpsslaserundefined
      dpsslaser
      duet 3d wifi ssid and password only take eeprom value into consideration!
      if i delete eeprom wifi sidd and password M588 S "*" then
      sd card ignores your a
      M589 S "DUET3D_2G" P "87654321" I192.168.4.1!
      firmware version 1.21!
        dpsslaser
        ; generated by RepRapFirmware Configuration Tool v2 on Thu Mar 07 2019 22:44:24 GMT+0100 (közép-európai téli idő)
        M552 S2
        M589 S"DUET3D_2G" P"87654321" I192.168.4.1
        ;M552 S1
        ;M587 S”yyyyyyyyy” P”xxxxxxxxx”
        M550 P"DUET3D" ; Set machine name
        M551 P"" ; Set password
        ;M552 S1 ; Enable network
        M552 P192.168.1.60
        M554 P192.168.1.1
        M553 P255.255.255.0
        M586 P0 S1 ; Enable HTTP
        M586 P1 S1 ; Enable FTP
        M586 P2 S1 ; Disable Telnet
        ;M588 S "*" ;clear wifi setting eeprom!
        ;AP mode config M589
        ;M552 S2
        ;M589 S"DUET3D_2" P"12345678" I192.168.4.1
        M569 P1 S1 ; Drive 1 goes forwards (Y1)
        M569 P4 S1 ; Drive 4 goes forwards (Y2)
        M584 X0 Y1:4 Z2 E3
        M92 X80.00 Y80.00 Z800.00 E145.75 ; Set steps per mm
        M566 X600.00 Y600.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
        M203 X18000.00 Y18000.00 Z180.00 E300.00 ; Set maximum speeds (mm/min)
        M201 X3000.00 Y3000.00 Z20.00 E10000.00 ; Set accelerations (mm/s^2)
        M906 X1300.00 Y1300.00 Z800.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M208 X300 Y300 Z300 S0 ; Set axis maxima
        M574 X1 Y1 Z1 S1 ; Set active high endstops
        M558 P0 H5 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed
        M557 X15:200 Y15:200 S20 ; Define mesh grid
        M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1 ;pid
        M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
        M307 H1 A650.5 C209.5 D8.4 S1.00 V11.7 B0 ;pid
        M106 P2 S0 I0 F500 H-1
        M563 P0 D0 H1 ; Define tool 0
        ; Automatic power saving
        M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
        ;M307 H2 A-1 C-1 D-1 ; Disable Heater E1 for use with the Berd-Air cooling
        ;M106 P0 A2 S0 F30000 ; Fan 0 (Part Cooler) using Heater E1 Mosfet; Custom settings are not configured
        ;M307 H2 A-1 C-1 D-1 ; disable heater 2 to make it available as a general purpose output pin
        ;M452 P2 R255 F200
        M307 H2 A-1 C-1 D-1
        M42 P2 S70 ;LED LIGHT RIBBON
        [c];Emergency Stop
        M581 T0 E0 S1 C0[/c] ; E1 input https://forum.duet3d.com/topic/4611/emergency-stop-configuration/2
        ;M581 T2 E1 S2 C0 ; T1 PAUSE, T0 EM-STOP https://forum.duet3d.com/topic/8793/emergency-stop-external-reset/6
        ;M574 E0 S0
        M582 T2
        M581 T2 E0 S1 C0
          I'm not sure I understand your issue.
          I suggest you remove the SSID setup commands from config.g and use either a PanelDue or USB terminal to send the command.
          1.21 is also quite old at this point. It may be time to look into upgrading to 2.03.
