    Programming a smart effector
    3.1k
    • ken340undefined
      ken340 @dc42
      @dc42 how do i programming the attiny44a already attached to smarteffector?
      • A Former User?
        A Former User
        there should be a 6 pin header "prog"
        Looks to be smd pads, so you'll have to use pogo pins or solder wires to the pads and use an avr programmer with atmel studio etc (you might get away with holding a non spring loaded header to the pads, but chances are its not a success)
        edit: whoa, missing linebreak
          Use https://hackaday.io/project/165027-avr-isp-pogo-pin-adapters or https://www.sparkfun.com/products/11591 or https://www.amazon.com/pin-AVR-ICSP-Pogo-Adapter/dp/B075Q25BK3 or similar to make the connections (search for "avr pogo" to find more). Or make your own as i did.
          • A Former User?
            A Former User
            or you could buy a bag of pins and print a holder; i managed to replicte the tc2030 tag connect recently with some 0.75 or 0.5mm pins and spring steel wire for the guide pins.
            if you get 1mm pins you can get receptacles with square posts that fit into the regular 2.54mm female idc, for that I just put he pins in the female header and squirted some hotglue on them while aligned but don't think i have a picture of that. never know when you'll need pins for something else.
              I used very short pogo pins soldered directly to a 2x3 header.
              • ken340undefined
                ken340
                Thanks all for the tips. unfortunately i am using mac, any recomendation for amtel studio alternative.
                • A Former User?
                  A Former User @ken340
                  @ken340 said in Programming a smart effector:
                  i think avrdude is available on most platforms and will work with pretty much any programmer. but you'll need to get a precompiled hex which i think dc42 has posted a link to here somewhere oin one of the old threads.
                  ken340undefined 1 Reply Last reply Reply Quote 0
                  • ken340undefined
                    ken340 @A Former User
                    @bearer great, i saw dc42 hex file on his github
                    • ken340undefined
                      ken340
                      The 3.3V from the pin will power the smart effector? how do i know it is connected correctly?
                      will those cheap USBasp work?
                      • A Former User?
                        thats a lottery, at least when using them with windows. using yet another programmer to reprogram the usbasp clone could be necessary, and you'll most likely be banging your head in some issues with drivers.
                        i'd generally recommend against it maybe you can refrence this post in case you have something else on hand that you can use already?
                        https://forum.duet3d.com/topic/15661/chip-burned-i-need-a-new-one?_=1597701384110
                        there is a bit more learning curve to getting an arduino pro mini + ftdi board, but it'll be much more versatile in the long run.
                        when it comes to 3.3v, make sure the programmer is also running of 3.3v to avoid 5v logic signals. the simplest test is to look at the wiring diagram and before turning on the power use a multimeter in continuity mode measure from 3.3v on the programmer to 3.3v on the target, repeat for ground, and round of checking there is no continuity between 3.3v and ground.
                          The Smart Effector can be programmed at either 3.3V or 5V, provided that is it not connected to a Duet at the time.
                          • ken340undefined
                            @bearer are they any way to know the pins are correctly connected. such as LED light up or something?
                            • A Former User?
                              A Former User
                              isn't the board clearly marked like so:
                              • uk25undefined
                                uk25
                                This post is deleted!
                                • ken340undefined
                                  ken340 @uk25
                                  @uvarovkv i did not make my own smart effector. i am trying on my purchased smarteffector. since productivity is low at work due to COVID-19 so i am taking time to learn more about this little marvel.
                                  when i connect 6 pogo pins to my smart effector without any power from duet. i am not getting my response from AVRdude using USBASP.
                                  therefore i am not sure whether i am not connecting via pogo pins correctly or my USBASP is not working well (I use it to program arduino without issue) .
                                  can you tell me with your connection to smarteffector for programming, do you get any physical indication like any LED is turned on? or there are no physical indication to tell the connection is good.
                                  • A Former User?
                                    A Former User
                                    if the leds come on when you power the smart effector from the duet then they should come on when you power it from the programmer as well. if the leds need running firmware to come on then your milage will vary.
                                    • ken340undefined
                                      ken340
                                      finally i mange to flash the smart effector with the hex file provided by dc42. but i am still having problem. the green light does not light up at all. also the probe function is not working.
                                      what else can i check?
