Trouble with E0 driver
  • Hello
    Ive had this amazing board Duet 2 wifi for 14 days with plenty joy , but last day i got this error when trying to extrude , Short to ground drivers 3 .I have tryed to disconnect the motor wire(powered off) and retry make it run but still same error . Did m122 and driver section shows :
    What happend and what can i do to make it work again , would be so frikkin happy for any help with this problem .
    Regards Kristian .
    I'm sorry, it looks like one of the stepper drivers has suffered infant mortality. If it's a genuine Duet then this is covered by the warranty, so you should contact your supplier to get it the Duet exchanged.
    If you want to postpone swapping the Duet for a few days, you can use the E1 motor output instead of E0 by adding this line to config.g (earlier than any M906 or M350 lines), assuming you don't already have a M584 command in config,g:
    M584 X0 Y1 Z2 E4
  • Hello dc42
    I did the remapping and are currently running again , i will talk to seller and work somthing out 🙂
    Regards Kristian .
  • Hi
    Just an small update , ive had the card switched out for replacement , and joy is once again restored . I greatly apriciate your customer service and time taken to help with solution .
    kind regards
    Kristian P.
    Thanks for the update! I'm sorry that this has inconvenienced you.
