    E1 filament sensor detection/configure
    626
    • trublu89undefined
      trublu89
      I have the duet ethernet and duex5 with the mmu2 hardware. Everything is setup minus the second filament sensor. It's connected on e1 endstop connector and I've tried every combination I can think of but I can't get the e1 status to show using 591 or m119. D0 endstop shows but when I use 591 D1 nothing shows. I even tried defining axis v with the endstop but nothing is triggering even though the light on the endstop goes on and off when the probe is manually touched with metal.
      • trublu89undefined
        trublu89
        So I changed my configuration to M591 D1 P2 C4 S1
        When I type M591 D1 in the console all I get is M591 nothing else.
        Board: Duet Ethernet 1.02 or later + DueX5
        Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.04RC1 (2019-07-14b1)
          Do you definitely have an extruder drive 1? Please post your complete config.g file.
          • trublu89undefined
            trublu89
            ; Communication and general
            M111 S0 ; Debug off
            M550 Sir ; Machine name and Netbios name (can be anything you like)
            M551 Preprap ; Machine password (used for FTP)
            M929 ;Enable logging
            *** Ethernet networking: The following lines are used for factory testing - PLEASE REMOVE THEM
            ;*** End of factory test lines to be removed
            ;*** Networking
            M552 S1 ; Turn network on
            M555 P2 ; Set output to look like Marlin
            G21 ; Work in millimetres
            ; Disable Fan 1 thermostatic mode
            M106 P1 H-1
            M667 S0 ;selects Cartesian mode
            ; Axis and motor configuration
            M569 P0 S1 ; Drive 0 goes forwards X
            M569 P1 S1 ; Drive 1 goes forwards Z
            M569 P2 S0 ; Drive 2 goes forwards Y
            M569 P3 S0 ; Drive 3 goes forwards E
            M569 P4 S0 ; Drive 4 goes backwards V
            M569 P5 S1 ; Drive 5 goes forwards U
            M569 P6 S0 ; Drive 6 goes forwards W
            M584 X0 Y1 Z2 E3 V4 U5 W6 ; Apply custom drive mapping
            ;Endstops
            M574 X1 Y1 S1 ; set endstop configuration (all endstops at high end, active high)
            M574 Z1 S2 ; Define z to use probe. Home to min
            ;M574 V P2 S0 C4
            M574 U1 V1 W1 S3 ; Set additional axes as sensorless endstops
            M591 D1 P2 C4 S1
            M591 D0 P2 C3 S1 ;Filament sensor extruder 0, simple sensor,
            ;M574 V1 S1
            ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration
            M350 X16 Y16 Z16 E16 U16 V16 W16 I1 ; Set 16x microstepping with interpolation
            M92 X79.5031056 Y640 Z400 U400 V145 W26 ; Set axis steps/mm
            ;M350 X4 Y4 Z16 E16:16 I1 ;x and y 1/4 step
            ;M92 X198.75 Y160 Z400
            ;M350 X6 Y6 Z16 E16:16 I1 ;x and y 1/4 step
            ;M92 X397.5 Y320 Z400
            M906 X2000 Y2000 Z850 E1200 I60 ; Set motor currents (mA) and increase idle current to 60%
            M906 U1000 V2000 W2000 I30 ; Set motor currents (mA) and increase idle current to 30%
            M201 X2000 Y1200 Z600 E2000 U500 V2000 W2000 ; Accelerations (mm/s^2)
            M203 X9000 Y1400 Z1000 E1080 U5000 V10000 W20000 ; Maximum speeds (mm/min)
            M204 P600 T10000 ; Set printing and travel accelerations
            ;M572 D0 S0.25 ; Pressure advance
            M566 X600 Y300 Z18 E400 U400 V2000 W2000 ; Maximum instant speed changes mm/minute
            M208 U0 V-1000 W0 S1 ; Set axis minimum
            M208 X845 Y519 Z380 ; set axis maxima
            M208 U75 V1000 W78 S0 ; Set axis maximum
            ; Thermistors
            ;M305 P0 T100000 B3950 R4700 H30 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
            M307 H0 A-1 C-1 D-1 ; Disable temp sensor, heater 0 is now GPI0
            ;BLTouch -Heaters
            M307 H7 A-1 C-1 D-1; ;Disabel the 7th Heater to free up PWM channel 5
            M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
            ;M305 P2 T100000 B3974 R4700 H30 L0 ; Put your own H and/or L values here to set 2nd nozzle thermistor ADC correction
            M570 S180 ; Hot end may be a little slow to heat up so allow it 180 seconds
            M140 H-1 ; Disable heated bed, this is controlled externally
            ; Adjustments for dummy heaters on test rig
            ;M307 H0 A250 C140 D5.5 B1
            ;M307 H1 A250 C140 D5.5 B0
            ;M307 H2 A250 C140 D5.5 B0
            M106 P1 S1 I0 F500 H T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
            ; Tool definitions
            M563 P1 D0 H1 ; Define tool 0
            G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
            ;*** If you have a single-nozzle build, comment the next 2 lines
            ;M563 P1 D1 H2 ; Define tool 1
            ;G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
            M92 E137.65 ; Set extruder steps per mm
            ; Z probe and compensation definition
            ;*** If you have a switch instead of an IR probe, change P1 to P4 in the following M558 command.
            M558 P5 H5 F300 T6000 X0 Y0 Z1 ; Set Z probe type/mode 5. H=Dive Height. Fspeed the bed moves Reduced F300 to ;100
            G31 P25 X13.2 Y0 Z0 ; Set the zprobe height and threshold for Smart Effector
            M557 x64:605 Y12:509 S40 ; define grid
            ;*** If you are using axis compensation, put the figures in the following command
            M556 S78 X0 Y0 Z0 ; Axis compensation here
            M208 S1 Z -2 ; set minimum Z
            G29 S1
            T0 ; select first hot end
            ; M117 Use https://configurator.reprapfirmware.org/ to set up your printer config
            ; Automatic power saving
            M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
            ;Tools
            M563 P0 D0 H1 ; Define tool 0
            M563 P1 D0 H1 ; Define tool 1
            G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets
            G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
            M563 P2 D0 H1 ; Define tool 2
            G10 P2 X0 Y0 Z0 ; Set tool 2 axis offsets
            G10 P2 R0 S0 ; Set initial tool 2 active and standby temperatures to 0C
            M563 P3 D0 H1 ; Define tool 3
            G10 P3 X0 Y0 Z0 ; Set tool 3 axis offsets
            G10 P3 R0 S0 ; Set initial tool 3 active and standby temperatures to 0C
            M563 P4 D0 H1 ; Define tool 4
            G10 P4 X0 Y0 Z0 ; Set tool 4 axis offsets
            G10 P4 R0 S0 ; Set initial tool 4 active and standby temperatures to 0C
            • trublu89undefined
              trublu89
              I've tried 122 as well and nothing about second filament sensor. I also just recently updated to the most recent firmware.
              • trublu89undefined
                trublu89
                Does my config look ok? I also updated to the latest firmware I didn't see anything change on the release notes.
                • dragontattooundefined
                  dragontattoo
                  okay fine
                  • trublu89undefined
                    trublu89
                    So I figured something out. When M591 D0 and what ever c* pin is entered it reads back the value of what ever endstop is configured the next time M591 D0 is entered.
                    Also I had the endstop connected with just a resistor and just recently changed it to a optocoupler but the pin is now reading always high. Is there a way to enable the internal resistor or remap the extruder pins on e1?
