    Filament runout sensor issues
    • Monster Delta
      Monster Delta last edited by
      ive got a simple microswitch type runout sensor but i'm having issues when i pull the filament out the board shuts down as if i hit the emergency stop and hen everything goes back to normal once filament is inserted again, this happens even when the printer is idle. the other thing that happens is the printer wants to pause as soon as the print starts when there is filament present
      • Jackal
        Jackal last edited by
        How do you wire your switch and what command have you set up to work with it?
        • Monster Delta
          Solved this now i had it wired wrong. i know its only 2 wires must of been a brain fart
