End codes
  • I have an FLSun Prusa clone that I have modified extensively and installed a Duet Maestro board.
    After a while of getting used to RepRap, I have it running pretty well.
    However, when I finish a print, the machine just stops. The fan on the hot end also stops, the nozzle welds itself to the part, the filament comes out, and after about 5 minutes, the machine then homes, pushing the part off the bed.
    where can I find the g codes for the end of a print?
  • OK, I found the G codes in the slicer software.
    I think the problem is that when the last layer is done, it's still printing. The end g code doesn't commence until several minutes later.
  • Moderator
    @san-juan said in End codes:
    What is the end gcode you are using?
