Temp controlled Fan setup for non-heater application
  • I am trying to setup a Chassis fan to suck out air from enclosure once the ambient enclosure temp exceeds say 65degC
    I have this setup as i am using PT100 sensors
    M143 H0 S160 ; Set temperature limit for heater 0 to 160C
    M305 P1 X201 ; Configure PT100 for heater 1
    M143 H1 S430 ; Set temperature limit for heater 1 to 430C
    M305 P2 X200 ; Configure PT100 for heater 2
    M143 H2 S430 ; Set temperature limit for heater 2 to 430C
    M305 P3 T100000 B4138 R4700
    Fan control something like this
    M106 P2 S0 T65 H3
    as using P2 Fan output.
    I wish to use a normal thermister on say E0 thermistor input as its not used due to PT100 Board
    I was playing with the M305 command to setup parameters for thermistor
    Is there a simple way for the M106 commane to read the thermistor channel, do i need to create a tool?
    What have i missed?
    some help would be greatly appreciated.
  • Any Help here. i can seem to read the onboard thermistors after i have the PT100 allocated to the Hot ends.
    For the time being i have my chamber fan turning on after the Bed gets to 130 Deg C.
    Use M305 to set up a virtual heater that uses that thermistor (e.g. heater 102), then use M106 to control the fan thermostatically from that heater number.
