Duet wifi not working after change wifi settings
@koli90 said in Duet wifi not working after change wifi settings:
The 'Diag' LED is constantly on. I tried erase board but I can not update board because BOSSA do not see the board.
When you say "I tried erase board", can you confirm that you fitted the Erase jumper and powered up the board, pr pressed the Erase button for one second or longer when the board was powered up (form USB will do)?
How hot does the MCU chip get? It's normal for it to run slightly warm, but not hot.
@dc42 Yes, I tried to follow https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware.
As for the temperature of the chip and after a while it gets pretty hot (I have no way to measure the temperature)
