    topic_unsolved z babystepping not working
    309
    • skhotso
      skhotso last edited by
      I have a duet wifi on my cr10 running the latest fw 2.04rc1. When I'm on my first layer and I click z babystepping up 0.05mm it does nothing. I've changed it all the way up to 3mm and the nozzle doesn't move up at all. Is there a trick to this in the DWC? I see the command being sent in the gcode console but zero movement.
      While the printer is idle, I click the babystepping and it responds instantly. I know it may have to finish a layer before processing the babystepping command but it never responds, layer after layer.
        Is your DWC version up to date as well?
        If you send a baby stepping command from the gcode console does it respond?
        • skhotso
          Yes. DWC 1.22.6
          If I send M290 S-0.05, nothing happens while it's printing, if I send the command while it is idle, it'll respond.
          I've tried M290 S2 and still nothing.
          • skhotso
            Any other ideas?
            • fcwilt
              fcwilt last edited by
              I just upgraded to 2.04 RC1 and tested baby stepping.
              I clicked the up button until the reading was 1 mm and it clearly moved the head.
              I was worried that it wasn't going to work but it did.
              • skhotso
                You clicked the button while it was idle or while it was printing something?
                fcwilt 1 Reply Last reply Reply Quote 0
                • fcwilt
                  fcwilt @skhotso last edited by
                  @skhotso said in z babystepping not working:
                  While it was printing and it clearly had an effect.
                  • skhotso
                    yeah...mine doesn't do that. Not sure if there is something in the sys files I didn't set up correctly.
                    • skhotso
                      doesn't look like this is getting many hits. I'm going to try formatting and reinstalling the dwc image.
                      • fcwilt
                        Did you check to see if the babystepping amount wasn't somehow set to zero or other very small amount?
                        • skhotso
                          I've changed it to 1mm and still no babystepping visible.
